Problem updating VMware Kernel Module after upgrade
    Thank you for your great effort upgrading to Percise Pangolin.
    I upgraded sucessfully but i have a problem running VMware Player after the upgrade. I get a message thats says:
    Before you can run VMware, several modules must be compiled and loaded into the running kernel.
    So I click install and it takes sometime while failing to install the virtual network devies module then gives an error message at the end saying:
    Unable to start services.
    See log file /tmp/vmware-root/modconfig-5201.log for details
    Any ideas?
    The source code for the modules requires some patches so that they'll compile with the 3.2 kernel.
    http://weltall.heliohost.org/wordpre...l-3-2-and-3-3/
      Thank you so much. I applied the patch and now VMware player runs perfectly.
