Problem with Akonadi
    I've just installed Kubuntu 14.04 64bit over my previous system, that was Kubuntu 12.04 32bit.
    The system is set up in two partitions, as usual, one where is insalle the root and another for the home folder.
    When installing I have formatted the root partition to instal the new system, but I have kept all files and settings in my home.
    Now it seems that Akonadi has some problems, and it won't start. whenever I try to run a program that depends on it, I receive various errors that prevent me to use those applications.
    This is the error dialog that I get when trying to start akonadi:
    while this is the full detailed report
    Akonadi Server Self-Test Report
    Test 1:  SUCCESS
    Database driver found.
    Details: The QtSQL driver 'QMYSQL' is required by your current Akonadi server configuration and was found on your system.
    File content of '/home/stefano/.config/akonadi/akonadiserverrc':
    [%General]
    Driver=QMYSQL
    [QMYSQL]
    Name=akonadi
    Host=
    Options="UNIX_SOCKET=/tmp/akonadi-stefano.mRVUgg/mysql.socket"
    ServerPath=/usr/sbin/mysqld-akonadi
    StartServer=true
    [Debug]
    Tracer=null
    Test 2:  SUCCESS
    Akonadi is not running as root
    Details: Akonadi is not running as a root/administrator user, which is the recommended setup for a secure system.
    Test 3:  SUCCESS
    MySQL server found.
    Details: You have currently configured Akonadi to use the MySQL server '/usr/sbin/mysqld-akonadi'.
    Make sure you have the MySQL server installed, set the correct path and ensure you have the necessary read and execution rights on the server executable. The server executable is typically called 'mysqld'; its location varies depending on the distribution.
    Test 4:  SUCCESS
    MySQL server is executable.
    Details: MySQL server found: 140426 12:20:01 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
    /usr/sbin/mysqld  Ver 5.5.35-1ubuntu1 for debian-linux-gnu on x86_64 ((Ubuntu))
    Test 5:  ERROR
    MySQL server log contains errors.
    Details: The MySQL server error log file &apos;<a href='/home/stefano/.local/share/akonadi/db_data/mysql.err'>/home/stefano/.local/share/akonadi/db_data/mysql.err</a>&apos; contains errors.
    File content of '/home/stefano/.local/share/akonadi/db_data/mysql.err':
    140426 12:19:57 [Note] Plugin 'FEDERATED' is disabled.
    140426 12:19:57 InnoDB: The InnoDB memory heap is disabled
    140426 12:19:57 InnoDB: Mutexes and rw_locks use GCC atomic builtins
    140426 12:19:57 InnoDB: Compressed tables use zlib 1.2.8
    140426 12:19:57 InnoDB: Using Linux native AIO
    140426 12:19:57 InnoDB: Initializing buffer pool, size = 80.0M
    140426 12:19:57 InnoDB: Completed initialization of buffer pool
    InnoDB: Unable to lock ./ibdata1, error: 11
    InnoDB: Check that you do not already have another mysqld process
    InnoDB: using the same InnoDB data or log files.
    140426 12:19:57  InnoDB: Retrying to lock the first data file
    140426 12:21:38  InnoDB: Unable to open the first data file
    InnoDB: Error in opening ./ibdata1
    140426 12:21:38  InnoDB: Operating system error number 11 in a file operation.
    InnoDB: Error number 11 means 'Resource temporarily unavailable'.
    InnoDB: Some operating system error numbers are described at
    InnoDB: http://dev.mysql.com/doc/refman/5.5/en/operating-system-error-codes.html
    140426 12:21:38 InnoDB: Could not open or create data files.
    140426 12:21:38 InnoDB: If you tried to add new data files, and it failed here,
    140426 12:21:38 InnoDB: you should now edit innodb_data_file_path in my.cnf back
    140426 12:21:38 InnoDB: to what it was, and remove the new ibdata files InnoDB created
    140426 12:21:38 InnoDB: in this failed attempt. InnoDB only wrote those files full of
    140426 12:21:38 InnoDB: zeros, but did not yet use them in any way. But be careful: do not
    140426 12:21:38 InnoDB: remove old data files which contain your precious data!
    140426 12:21:38 [ERROR] Plugin 'InnoDB' init function returned error.
    140426 12:21:38 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
    140426 12:21:38 [ERROR] Unknown/unsupported storage engine: innodb
    140426 12:21:38 [ERROR] Aborting
    140426 12:21:38 [Note] /usr/sbin/mysqld: Shutdown complete
    Test 6:  SUCCESS
    MySQL server default configuration found.
    Details: The default configuration for the MySQL server was found and is readable at <a href='/etc/akonadi/mysql-global.conf'>/etc/akonadi/mysql-global.conf</a>.
    File content of '/etc/akonadi/mysql-global.conf':
    # Global Akonadi MySQL server settings,
    # These settings can be adjusted using $HOME/.config/akonadi/mysql-local.conf
    # Based on advice by Kris Köhntopp <kris@mysql.com>
    [mysqld]
    # strict query parsing/interpretation
    # TODO: make Akonadi work with those settings enabled
    # sql_mode=strict_trans_tables,strict_all_tables,strict_error_for_division_by_zero,no_auto_create_user,no_auto_value_on_zero,no_engine_substitution,no_zero_date,no_zero_in_date,only_full_group_by,pipes_as_concat
    # DEBUGGING:
    # log all queries, useful for debugging but generates an enormous amount of data
    # log=mysql.full
    # log queries slower than n seconds, log file name relative to datadir (for debugging only)
    # log_slow_queries=mysql.slow
    # long_query_time=1
    # log queries not using indices, debug only, disable for production use
    # log_queries_not_using_indexes=1
    # mesure database size and adjust innodb_buffer_pool_size
    # SELECT sum(data_length) as bla, sum(index_length) as blub FROM information_schema.tables WHERE table_schema not in ("mysql", "information_schema");
    # NOTES:
    # Keep Innob_log_waits and keep Innodb_buffer_pool_wait_free small (see show global status like "inno%", show global variables)
    #expire_logs_days=3
    #sync_bin_log=0
    # Use UTF-8 encoding for tables
    character_set_server=utf8
    collation_server=utf8_general_ci
    # use InnoDB for transactions and better crash recovery
    default_storage_engine=innodb
    # memory pool InnoDB uses to store data dictionary information and other internal data structures (default:1M)
    # Deprecated in MySQL >= 5.6.3
    innodb_additional_mem_pool_size=1M
    # memory buffer InnoDB uses to cache data and indexes of its tables (default:128M)
    # Larger values means less I/O
    innodb_buffer_pool_size=80M
    # Create a .ibd file for each table (default:0)
    innodb_file_per_table=1
    # Write out the log buffer to the log file at each commit (default:1)
    innodb_flush_log_at_trx_commit=2
    # Buffer size used to write to the log files on disk (default:1M for builtin, 8M for plugin)
    # larger values means less I/O
    innodb_log_buffer_size=1M
    # Size of each log file in a log group (default:5M) larger means less I/O but more time for recovery.
    innodb_log_file_size=64M
    # # error log file name, relative to datadir (default:hostname.err)
    log_error=mysql.err
    # print warnings and connection errors (default:1)
    log_warnings=2
    # Convert table named to lowercase
    lower_case_table_names=1
    # Maximum size of one packet or any generated/intermediate string. (default:1M)
    max_allowed_packet=32M
    # Maximum simultaneous connections allowed (default:100)
    max_connections=256
    # The two options below make no sense with prepared statements and/or transactions
    # (make sense when having the same query multiple times)
    # Memory allocated for caching query results (default:0 (disabled))
    query_cache_size=0
    # Do not cache results (default:1)
    query_cache_type=0
    # Do not use the privileges mechanisms
    skip_grant_tables
    # Do not listen for TCP/IP connections at all
    skip_networking
    # The number of open tables for all threads. (default:64)
    table_open_cache=200
    # How many threads the server should cache for reuse (default:0)
    thread_cache_size=3
    # wait 365d before dropping the DB connection (default:8h)
    wait_timeout=31536000
    # We use InnoDB, so don't let MyISAM eat up memory
    key_buffer_size=16K
    [client]
    default-character-set=utf8
    Test 7:  SKIP
    MySQL server custom configuration not available.
    Details: The custom configuration for the MySQL server was not found but is optional.
    Test 8:  SUCCESS
    MySQL server configuration is usable.
    Details: The MySQL server configuration was found at <a href='/home/stefano/.local/share/akonadi/mysql.conf'>/home/stefano/.local/share/akonadi/mysql.conf</a> and is readable.
    File content of '/home/stefano/.local/share/akonadi/mysql.conf':
    [mysqld]
    # DEBUGGING:
    # log=mysql.full
    # long_query_time=1
    # NOTES:
    #expire_logs_days=3
    #sync_bin_log=0
    log_error=mysql.err
    log_warnings=2
    max_connections=256
    query_cache_size=0
    query_cache_type=0
    skip_grant_tables
    skip_networking
    thread_cache_size=3
    key_buffer_size=16K
    [client]
    Test 9:  SUCCESS
    akonadictl found and usable
    Details: The program '/usr/bin/akonadictl' to control the Akonadi server was found and could be executed successfully.
    Result:
    Akonadi 1.12.1
    Test 10:  ERROR
    Akonadi control process not registered at D-Bus.
    Details: The Akonadi control process is not registered at D-Bus which typically means it was not started or encountered a fatal error during startup.
    Test 11:  ERROR
    Akonadi server process not registered at D-Bus.
    Details: The Akonadi server process is not registered at D-Bus which typically means it was not started or encountered a fatal error during startup.
    Test 12:  SKIP
    Protocol version check not possible.
    Details: Without a connection to the server it is not possible to check if the protocol version meets the requirements.
    Test 13:  ERROR
    No resource agents found.
    Details: No resource agents have been found, Akonadi is not usable without at least one. This usually means that no resource agents are installed or that there is a setup problem. The following paths have been searched: '/usr/share/akonadi/agents'. The XDG_DATA_DIRS environment variable is set to '/usr/share:/usr/share/kde-plasma:/usr/local/share/:/usr/share/'; make sure this includes all paths where Akonadi agents are installed.
    Directory listing of '/usr/share/akonadi/agents':
    akonadibalooindexingagent.desktop
    akonadinepomukfeederagent.desktop
    akonotesresource.desktop
    archivemailagent.desktop
    birthdaysresource.desktop
    contactsresource.desktop
    davgroupwareresource.desktop
    facebookresource.desktop
    folderarchiveagent.desktop
    googlecalendarresource.desktop
    googlecontactsresource.desktop
    icaldirresource.desktop
    icalresource.desktop
    imapresource.desktop
    invitationsagent.desktop
    kabcresource.desktop
    kalarmdirresource.desktop
    kalarmresource.desktop
    kcalresource.desktop
    kdeaccountsresource.desktop
    kolabproxyresource.desktop
    localbookmarksresource.desktop
    maildirresource.desktop
    maildispatcheragent.desktop
    mailfilteragent.desktop
    mboxresource.desktop
    migrationagent.desktop
    mixedmaildirresource.desktop
    mtdummyresource.desktop
    newmailnotifieragent.desktop
    nntpresource.desktop
    notesagent.desktop
    openxchangeresource.desktop
    pop3resource.desktop
    sendlateragent.desktop
    vcarddirresource.desktop
    vcardresource.desktop
    Environment variable XDG_DATA_DIRS is set to '/usr/share:/usr/share/kde-plasma:/usr/local/share/:/usr/share/'
    Test 14:  ERROR
    Current Akonadi server error log found.
    Details: The Akonadi server reported errors during its current startup. The log can be found in <a href='/home/stefano/.local/share/akonadi/akonadiserver.error'>/home/stefano/.local/share/akonadi/akonadiserver.error</a>.
    File content of '/home/stefano/.local/share/akonadi/akonadiserver.error':
    DATABASE ERROR:
      Error code: 1048
      DB error:  "Column 'name' cannot be null"
      Error text: "Column 'name' cannot be null QMYSQL3: Unable to execute statement"
      Query: "INSERT INTO PartTypeTable (ns, name) VALUES (:0, :1)"
    Update failed
    Failed to commit transaction for database update
    Unable to initialize database.
    0: akonadiserver() [0x419cb7]
    1: akonadiserver() [0x419f12]
    2: /lib/x86_64-linux-gnu/libc.so.6(+0x36ff0) [0x7f0b999d9ff0]
    3: /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x39) [0x7f0b999d9f79]
    4: /lib/x86_64-linux-gnu/libc.so.6(abort+0x148) [0x7f0b999dd388]
    5: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_Z17qt_message_output9QtMsgTypePKc+0x102) [0x7f0b9b4c1c92]
    6: akonadiserver() [0x41bdbd]
    7: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN9QIODevice5writeEPKcx+0xb0) [0x7f0b9b55c470]
    8: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x11ab3d) [0x7f0b9b56bb3d]
    9: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN11QTextStreamD1Ev+0x31) [0x7f0b9b574721]
    10: akonadiserver() [0x41f72b]
    11: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN7QObject5eventEP6QEvent+0x24e) [0x7f0b9b5e6c1e]
    12: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN16QCoreApplication14notifyInternalEP7QObjectP6QEvent+0x6d) [0x7f0b9b5ce4dd]
    13: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData+0x1ed) [0x7f0b9b5d1b3d]
    14: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x1aaf83) [0x7f0b9b5fbf83]
    15: /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x254) [0x7f0b990a8e04]
    16: /lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x49048) [0x7f0b990a9048]
    17: /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x2c) [0x7f0b990a90ec]
    18: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+0x71) [0x7f0b9b5fb7a1]
    19: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN10QEventLoop13processEventsE6QFlagsINS_17ProcessEventsFlagEE+0x2f) [0x7f0b9b5cd0af]
    20: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE+0x175) [0x7f0b9b5cd3a5]
    21: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN16QCoreApplication4execEv+0x89) [0x7f0b9b5d2b79]
    22: akonadiserver() [0x4142e7]
    23: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f0b999c4ec5]
    24: akonadiserver() [0x414c48]
    Test 15:  ERROR
    Previous Akonadi server error log found.
    Details: The Akonadi server reported errors during its previous startup. The log can be found in <a href='/home/stefano/.local/share/akonadi/akonadiserver.error.old'>/home/stefano/.local/share/akonadi/akonadiserver.error.old</a>.
    File content of '/home/stefano/.local/share/akonadi/akonadiserver.error.old':
    DATABASE ERROR:
      Error code: 1048
    Update failed
    2: /lib/x86_64-linux-gnu/libc.so.6(+0x36ff0) [0x7f27bde61ff0]
    3: /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x39) [0x7f27bde61f79]
    4: /lib/x86_64-linux-gnu/libc.so.6(abort+0x148) [0x7f27bde65388]
    5: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_Z17qt_message_output9QtMsgTypePKc+0x102) [0x7f27bf949c92]
    7: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN9QIODevice5writeEPKcx+0xb0) [0x7f27bf9e4470]
    8: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x11ab3d) [0x7f27bf9f3b3d]
    9: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN11QTextStreamD1Ev+0x31) [0x7f27bf9fc721]
    11: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN7QObject5eventEP6QEvent+0x24e) [0x7f27bfa6ec1e]
    12: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN16QCoreApplication14notifyInternalEP7QObjectP6QEvent+0x6d) [0x7f27bfa564dd]
    13: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData+0x1ed) [0x7f27bfa59b3d]
    14: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x1aaf83) [0x7f27bfa83f83]
    15: /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x254) [0x7f27bd530e04]
    16: /lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x49048) [0x7f27bd531048]
    17: /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x2c) [0x7f27bd5310ec]
    18: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+0x71) [0x7f27bfa837a1]
    19: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN10QEventLoop13processEventsE6QFlagsINS_17ProcessEventsFlagEE+0x2f) [0x7f27bfa550af]
    20: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE+0x175) [0x7f27bfa553a5]
    21: /usr/lib/x86_64-linux-gnu/libQtCore.so.4(_ZN16QCoreApplication4execEv+0x89) [0x7f27bfa5ab79]
    23: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f27bde4cec5]
    Test 16:  SUCCESS
    No current Akonadi control error log found.
    Details: The Akonadi control process did not report any errors during its current startup.
    Test 17:  SUCCESS
    No previous Akonadi control error log found.
    Details: The Akonadi control process did not report any errors during its previous startup.
    How can I solve this, so I can use applications dependent on akonadi again?
    See https://www.kubuntuforums.net/showth...l=1#post338103
      Thanks, now it works perfectly.
