notify-send --- --urgency equals critical doesn't work?
    [SOLVED] notify-send --- --urgency equals critical doesn't work?
    Looks like kdialog --passivepopup "whatever message" is the way.
    According to man notify-send,
    OPTIONS
    -u, --urgency=LEVEL Specifies the urgency level (low, normal, critical).
    -t, --expire-time=TIME
           The  duration,  in milliseconds, for the notification to appear on screen.
           (Ubuntu's Notify OSD and GNOME Shell both ignore this parameter.)
    notify-send --urgency=critical "DONE"' doesn't work for me: the notification disappears after a few seconds.
    I can extend the time for which the notification is on the screen with notify-send --expire-time=50000 "DONE" but I want a notification to go away only when I dismiss it. Is that possible?
    My tea-timer (sudo apt install kteatime) tells me it's possible to have a notification stay visible until dismissed. Does "KDE" have its own notification system? If so, where is that info to allow users to have their own custom notifications?
    Kubuntu 20.04
    ... I want a notification to go away only when I dismiss it. Is that possible?
    I think it may be, because it changed some time after 18.04. In 20.04, the notification settings looks like this:
    and the one set by notify-send -u critical smile persists as I'm typing this. With 18.04 notifications of any urgency didn't last long, even in the notifications applet, and I often missed them.
      I think it may be, because it changed some time after 18.04. In 20.04, the notification ... set by [/console]notify-send -u critical smile[/console] persists as I'm typing this. With 18.04 notifications of any urgency didn't last long, even in the notifications applet, and I often missed them.
      Thanks! The nice thing with the 20.04 notification is a timer showing its "age" (in minutes).
      Kubuntu 20.04
