GIMP's GUI reads English despite of Plasma's regional setting - French in my case
    [SOLVED] GIMP's GUI reads English despite of Plasma's regional setting - French in my case
    Although I had installed Kubuntu 20.04 using French language from the start, GIMP's GUI was reading English...
    Despite of the fact that GIMP's Preferences > Interface > Language option was set to "System language" by default.
    But I've noticed that Ubuntu package language-pack-gnome-fr was not installed on my machine.
    Installing it was enough to solve this issue with GIMP's GUI
    As a side note, here were Ubuntu language packages installed by default while installing Kubuntu 20.04 (obviously not enough!):
    language-pack-en-base/focal,focal,now 1:20.04+20200416 all [installé]
    language-pack-en/focal,focal,now 1:20.04+20200416 all [installé]
    language-pack-fr-base/focal,focal,now 1:20.04+20200416 all [installé, automatique]
    language-pack-fr/focal,focal,now 1:20.04+20200416 all [installé]
    language-pack-kde-en/focal,focal,now 1:19.10.0ubuntu1 all [installé]
    language-pack-kde-fr/focal,focal,now 1:19.10.0ubuntu1 all [installé]
    I hope this post can speed up resolution for others facing the same issue...
    Thank you.
    There's something screwy in language handling of GTK apps in Kubuntu 20.04. When I release upgraded from 19.10 all my GTK apps started using French! So did a lot of command line programmes. Even gvim and vim. I had French as the third language in system settings, after British and American English. While I love French (what I can remember of it), I've never used it on a computer. I think I added the language to get some diacritics, or maybe ligatures like "œ". I did not have language-pack-gnome-fr or language-pack-gnome-en installed.
      Dear Valdo,
      thank you very much for the solution.
      I have had the same problem with GIMP and German localisation.
      After installing language-pack-gnome-de via apt (language-pack-gnome-de-base was installed automatically by this) GIMP is finally localised.
      Krita 4.2.9 is still American-English-only, though (will open a seperate thread for Krita these days)…
      Everyone have a nice weekend! :-)
      get rid of Snap scriptreinstall Snap for release-upgrade scriptinstall traditional Firefox script
        Dear Valdo,
        Did you try installing language-pack-kde-de as well?
        Just saying in case any KDE user needs such package.
        Multibooting: Kubuntu Jammy 22.04
        Before: Focal 20.04, Precise 12.04 Xenial 16.04 and Bionic 18.04
        Win / & 10 sadly
        Using Linux since June, 2008
          I did not explicitly install language-pack-kde-de, but it was already installed by default (I think KDE language packs are automatically installed when you chose localised keyboard settings during the installation).
          I think on Valdo's computer language-pack-kde-fr was also already there as he wrote so…
            Oh you're right! I hadn't noticed about Krita yet
            Well, that one is simple to fix:
            $ sudo apt install krita-l10n
            Another issue is that Krita systematically crashes on exit... but that should be raised to https://bugs.kde.org/ (if not already done by someone else, I didn't check).
              Thanks for your post, very help for me!
              In my case, I was have the same problem (in my case my system language is spanish) and gimp appears in english.
              Like you indicate, with the package language-pack-gnome-es the problem solved.
              The others packages, like you indicate, are installed automatic.
              Again, thanks.
