keyboard indicator in system tray
    [SOLVED] keyboard indicator in system tray
    somehow I deleted the system tray in the panel. Had no idea what happened. Tried to re-install the widgets. No good.Finally re-installed the system tray and the widgets inside it popped back in.
    Great. But the keyboard indicator now doesn't detect the numlock. It detects caps lock fine.
    I noticed that when I was trying to re-install the widgets, I installed the battery widget and it thought there wasn't any battery on my laptop. Noticed that the add widgets panel indicated 2 battery widgets?? So the one that was supposed to be in the deleted system tray was still active and blocking the second one from detecting the battery - my interpretation.
    Could there be 2 keyboard indicator widgets even though the add widgets panel only lists one?
    I have been trying to delete the keyboard indicator in the system tray and then re-install to see what happens, but the usual method I use for deleting widgets will only delete the system tray and nothing in the system tray.
    1. How does one delete a widget in the system tray?
    and
    2. Any ideas what is going on with the keyboard indicator not detecting the numlock. I have a dual boot with Kubuntu an Ubuntu and booted into Ubuntu and the numlock was detected there. So that seemed to rule out h/w. Also, the numlock key does work, just keyboard indicator no longer detects it.
    Any thoughts on how to get the keyboard indicator to detect numlock??
    geezer
