WIFI 5Ghz network card
    Hi Guys
    Can you tell me which network card works with 5Ghz, with built in drivers?
    Or where can I find that list?
    I once tested a TPlink, but it didn't worked...
    Thanks
    It depends on the chip on your mobo. What does lspci or lshw show?
      I want to use a USB one.
      This is my lspci:
      00:00.0 Host bridge: Intel Corporation 4th Gen Core Processor DRAM Controller (rev 06)
      00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06)
      00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05)
      00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
      00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 05)
      00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d5)
      00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d5)
      00:1c.5 PCI bridge: Intel Corporation 82801 PCI Bridge (rev d5)
      00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 05)
      00:1f.0 ISA bridge: Intel Corporation H81 Express LPC Controller (rev 05)
      00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05)
      00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
      01:00.0 VGA compatible controller: NVIDIA Corporation GK106 [GeForce GTX 650 Ti] (rev a1)
      01:00.1 Audio device: NVIDIA Corporation GK106 HDMI Audio Controller (rev a1)
      03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
      04:00.0 PCI bridge: ASMedia Technology Inc. ASM1083/1085 PCIe to PCI Bridge (rev 04)
      05:00.0 Multimedia audio controller: Creative Labs EMU10k1 [Sound Blaster Live! Series] (rev 06)
      05:00.1 Input device controller: Creative Labs SB Live! Game Port (rev 06)
      Thanks
        Intel wifi is almost always well supported, and many have 5ghz. Are you looking for a usb dongle, or for an addon pci card?
          From the list in this link, which is supposed to be filtered on "linux", find one which actually has Linux listed in the compatibility list and includes 5G. Comment sections usually include remarks about Linux as well.
          https://www.amazon.com/s?k=linux+com...ref=nb_sb_noss
          My mobo has a Atheros AR9462 Wireless Network Adapter chip. It is rated at a max speed of 256 Mbps. When my ISP was spectrum and I was paying $70/mo for 40Mbps, that chip was OK. Switching to a fiber optic ISP I bought 100 Mbps for $70/mo. Then, gratis, my ISP jacked my speed to 300 Mbps, and earlier this January to 500 Mbps while still only charging $70/mo. So now, I can use only half of my bandwidth because my chip is too slow. However, all is not lost. We also have two smartphones and two smart TV's, an IPv6 tunnel, and my wife's notebook that can take up part of the bandwidth. Seven devices all sucking on a 500 Mbps pipe. Only recently, during the covid-19 crisis, have I noticed that YT occasionally has a spinning wheel, something I never got since moving to fiber.
            Well, for Amazon as a resource, check this out
            https://www.amazon.com/customerpicks...bed29e725e2ec5
            I don't think many, if any USB dongles use Intel chips
              Yeah, I'm trying to find a USB adapter.
              I will take a look at those links.
              Thanks guys.
                Just an update for anyone who might need the same.
                I got this Edimax EW-7811UAC, installed the driver like they say here: https://edimax.freshdesk.com/support...gher-than-v4-1
                And finally I have 5Ghz internet.
                Everything OK now.
