Everything is terribly slow when booting on battery power
    [SOLVED] Everything is terribly slow when booting on battery power
    Hi all,
    Have kubuntu 19.10 on my Lenovo T495, and along with suspension problems, the only issue I continue to have is that when I boot on battery power everything is terribly slow. Yet when I boot with the laptop plugged in everything is normal and I can then unplug as much as I want and work for hours on battery with no slowdown whatsoever. But if I make the mistaking of rebooting without plugging back in - slows to a crawl.
    I've noticed this didin't happen running kernel 5.1.16 but I have to run 5.3+ because otherwise audio capture is junk.
    Any thoughts? Advice?
    Thanks. K
    Doesn't seem to be an issue any longer. Just installed a large set of updates. Not sure if that fixed it or what. But closing thread.
