Problem with GIMP opening from web.
    Hi all.
    I'm having trouble trying to open an image file (whatever the type) with GIMP when downloading it directly from the web. For example, if I'm in Google Photos and want to download a picture and instead of selecting "save file" I choose "open with", I can do that with Gwenview just OK, but if I change to GIMP, nothing happens.
    I can always save the file to disk and then open it with GIMP, but it's annoying not being able to do it straight from the site.
    As usual, many thanks in advance!
    I'm using Firefox 74.0, by the way, and I've been having this problem in previous iterations too. GIMP is 2.10.18 flatpak.
    I find that Firefox offers, as an alternative to Gwenview, one other application called "env". If I choose it, nothing happens either. Strange.
      Hey there, @Fernando. I haven't been around lately, so I just now read this thread. I can't honestly say I recall ever doing what you're attempting to do, but I'll give it a try tomorrow or the next day and report back.
      Just to be clear, does it matter where the image is? You mentioned Google Photos, but was that simply an example, and you get the same results elsewhere?
        Could GIMP being a flatpack be the reason?
        Have to tried it with the GIMP version from the (K)ubuntu repositories?
        And if you do need a more recent version, here is a PPA:
        https://launchpad.net/~otto-kesselgu...es_filter=eoan
          1 Does Gimp itself have support for opening files from the internet (or rather downloading to temp them opening)
          the flatpak opens external images just fine, via the file>> open location option, so it definitely is not blocked in the flatpak sandboxing.
          2 does this happen in the current FF 76, 19.10 has this
          Also, does it work with a 'normal' gimp?.
          3 there is an extension for opening images with gimp which may be helpful
          4 I can't find for the life of me see how to get FF to even prompt me with an 'open with' dialog to test with
          5 with google photos, the url for image being displayed does not include an actual proper image file name, though the 'download' or 'save image \ as' context menu does give an actual jpg file.
          an example from my account : https://photos.google.com/photo/AF1Q...HW21bKWyItsGId Note the lack of 'jpg' etc
          If the browser is passing this to Gimp, it definitely won't open it.
            Hi!
            Yes, it is! Why is that relevant?
            I have, buy I found other issues that made me go the flatpak route.
            No, it doesn't matter where I'm trying to download from. It's always the same.
            It should have, I used to be able to do that when I had it from the regular repositories...
            On Google Photos, for instance, just visualize a picture and clic on the "download" icon, FF offers (accorsing to your settings) the possibility to save the file to your HD or open with... and a default app or the option to choose a different one.
            I think the fact that my GIMP coems from a flatpak might be the problem, although I don't know why... Anyway, thanks everybody!
              I tried it. Gimp 2.8.22 (repositories). FF 76.0.1. Download, Open with, Gnu image manipulation program. It opens in Gimp.
