Results 1 to 10 of 10
Thread: Hot keys not working
  1. Back To Top    #1
    Ghost in the Machine Teunis's Avatar
    Join Date
    Jun 2006
    Location
    The Netherlands, 5m. below sea level.
    Posts
    3,615
    Threads
    173
    Local Date
    Jun 6th 2020
    Local Time
    11:08 AM
    Since years I use a bunch of Meta+* hotkeys but right now only one is working, Meta+D opens Dolphin.
    Settings were made as before and in System Settings (Global hotkeys) they are as expected yet they don't seem to work.
    Any ideas where I should look for a solution?
  2. Back To Top    #2
    Kubuntu as a Second Language
    Join Date
    Mar 2013
    Posts
    1,195
    Threads
    192
    Local Date
    Jun 6th 2020
    Local Time
    09:08 AM
    I've always put mine in Custom Shortcuts, not in Global Shortcuts. BTW, Meta+E is already a shortcut for Dolphin (in Global Shortcuts).
    Meta+T for konsole
    Meta+K for Kate
    Meta+F for Firefox all work (in Custom Shortcuts).
    Kubuntu 18.04 with Baloo file search and content indexing
    KDE neon 18.04 User Edition with Baloo file search and content indexing
  3. Back To Top    #3
    Join Date
    Jun 2006
    Location
    Posts
    3,615
    Threads
    173
    Local Date
    Jun 6th 2020
    Local Time
    11:08 AM
    Yes some come set in the default install and normally I change them to my way, like Meta+N for Firefox (from the days of Netscape...)
    Another way to change and access these settings is by right klicking the menu button and selecting editing applications but whatever I fill in nothing works.
  4. Back To Top    #4
    Join Date
    Mar 2013
    Posts
    1,195
    Threads
    192
    Local Date
    Jun 6th 2020
    Local Time
    09:08 AM
    Could there be a permissions problem?
  5. Back To Top    #5
    Join Date
    Jun 2006
    Location
    Posts
    3,615
    Threads
    173
    Local Date
    Jun 6th 2020
    Local Time
    11:08 AM
    Unlikely because one works, but how to find out?
  6. Back To Top    #6
    Join Date
    Mar 2013
    Posts
    1,195
    Threads
    192
    Local Date
    Jun 6th 2020
    Local Time
    09:08 AM
    Quote Originally Posted by Teunis View Post
    find . '!' -user $USER -ls
    identifies files not owned by you.
  7. Back To Top    #7
    Join Date
    Jun 2006
    Location
    Posts
    3,615
    Threads
    173
    Local Date
    Jun 6th 2020
    Local Time
    11:08 AM
    Good tip!
    But no dice, only the link to an extra drive shows up. (as owned by root)
  8. Back To Top    #8
    Join Date
    Mar 2013
    Posts
    1,195
    Threads
    192
    Local Date
    Jun 6th 2020
    Local Time
    09:08 AM
    Can you try with a new user? Will things work with the new user?
  9. Back To Top    #9
    Join Date
    Mar 2013
    Posts
    1,195
    Threads
    192
    Local Date
    Jun 6th 2020
    Local Time
    09:08 AM
    I just checked again after today's updates. Custom shortcuts can be added just fine.
    The two files written when a custom shortcut is added/modified are
    ~/.config/khotkeysrc
    and
    ~/.config/kglobalshortcutsrc
    (Mine is a clean install of 20.04.)
  10. Back To Top    #10
    Join Date
    Jun 2006
    Location
    Posts
    3,615
    Threads
    173
    Local Date
    Jun 6th 2020
    Local Time
    11:08 AM
    After a third(!) full reinstall I've got it working this morning, just a new user made no difference.
    And I don't have a clue why it failed before.
    Except maybe a very recent update to some library.
    Thanks for the suggestions!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
