Driver Management Software - Intel Wireless 8260 system alert
    Thinkpad x260 running 18.04
    I just got a system notification saying something something default drivers. I clicked on it and got this:
Name:	Intel 8260 Driver Screenshot.png
    A quick search found this Intel page on Linux wifi drivers, which I don't really know what, if anything to do with.
    https://www.intel.com/content/www/us...etworking.html
    On the surface, it looks like the default driver is at least a native Intel driver... maybe.
    My wifi can be a bit wonky at times, dropping out for no reason I can detect. But a restart usually takes care of it.
    Do I need to be concerned? Is there something I should look into here?
    That is a newer native kernel driver module for the wifi card, backported from a newer kernel. You should be able to use it, it probably fixes issues you are seeing. You should be able to revert back if necessary.
      How do I use it?
        Originally posted by TwoFistedJustice View Post
        How do I use it?
        I had the same. Ticked the checkbox and pressed OK. Hasn't bothered me ever since
