Problems With 5.3 Kernels
    [DESKTOP] Problems With 5.3 Kernels
    Hi all,
    I'm having a couple bugs with the 5.3.0-x kernels that I'm not sure how to troubleshoot. With 5.3.0-23, I can't enter my WiFi password. Pressing enter on the prompt just brings it back up. With 5.3.0-24, I can't login to my system. When I enter my password it shows my background and then freezes; I can't even get a tty. I can get a tty from the login screen just fine, though. Below is the output from hwinfo|less, if that helps figure things out. Thanks!
    phil-desktop
    description: Desktop Computer
    product: Z170N-WIFI (Default string)
    vendor: Gigabyte Technology Co., Ltd.
    version: Default string
    serial: Default string
    width: 64 bits
    capabilities: smbios-3.0.0 dmi-3.0.0 smp vsyscall32
    configuration: boot=normal chassis=desktop family=Default string sku=Default string uuid=1C021B03-0D04-6505-4D06-D30700080009
    *-core
    description: Motherboard
    product: Z170N-WIFI-CF
    physical id: 0
    version: x.x
    slot: Default string
    *-firmware
    description: BIOS
    vendor: American Megatrends Inc.
    physical id: 0
    version: F20
    date: 11/04/2016
    capacity: 8MiB
    capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int14serial int17printer acpi usb biosbootspecification uefi
    *-memory
    description: System Memory
    physical id: 3d
    slot: System board or motherboard
    *-bank:0
    description: DIMM DDR4 Synchronous 2133 MHz (0.5 ns)
    product: CMK16GX4M2B3000C15
    vendor: AMI
    physical id: 0
    serial: 00000000
    slot: ChannelA-DIMM0
    width: 64 bits
    clock: 2133MHz (0.5ns)
    *-bank:1
    description: [empty]
    physical id: 1
    slot: ChannelA-DIMM1
    *-bank:2
    vendor: AMI
    physical id: 2
    serial: 00000000
    slot: ChannelB-DIMM0
    width: 64 bits
    *-bank:3
    physical id: 3
    slot: ChannelB-DIMM1
    *-cache:0
    description: L1 cache
    physical id: 43
    slot: L1 Cache
    capacity: 256KiB
    capabilities: synchronous internal write-back unified
    configuration: level=1
    *-cache:1
    description: L2 cache
    physical id: 44
    slot: L2 Cache
    capacity: 1MiB
    configuration: level=2
    *-cache:2
    description: L3 cache
    physical id: 45
    slot: L3 Cache
    capacity: 6MiB
    configuration: level=3
    *-cpu
    description: CPU
    product: Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
    vendor: Intel Corp.
    physical id: 46
    bus info: cpu@0
    version: Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
    serial: To Be Filled By O.E.M.
    slot: U3E1
    capacity: 4005MHz
    width: 64 bits
    clock: 100MHz
    capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp md_clear flush_l1d cpufreq
    configuration: cores=4 enabledcores=4 threads=4
    *-pci
    description: Host bridge
    product: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers
    vendor: Intel Corporation
    physical id: 100
    bus info: pci@0000:00:00.0
    version: 07
    width: 32 bits
    clock: 33MHz
    configuration: driver=skl_uncore
    resources: irq:0
    *-pci:0
    description: PCI bridge
    product: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16)
    physical id: 1
    bus info: pci@0000:00:01.0
    version: 07
    width: 32 bits
    clock: 33MHz
    capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
    configuration: driver=pcieport
    resources: irq:121 ioport:e000(size=4096) memory:efe00000-efefffff ioport:d0000000(size=270532608)
    *-display
    description: VGA compatible controller
    product: Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: Advanced Micro Devices, Inc. [AMD/ATI]
    physical id: 0
    bus info: pci@0000:01:00.0
    version: c7
    width: 64 bits
    clock: 33MHz
    capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
    configuration: driver=amdgpu latency=0
    resources: irq:141 memory:d0000000-dfffffff memory:e0000000-e01fffff ioport:e000(size=256) memory:efe00000-efe3ffff memory:c0000-dffff
    *-multimedia
    description: Audio device
    product: Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    physical id: 0.1
    bus info: pci@0000:01:00.1
    version: 00
    width: 64 bits
    clock: 33MHz
    capabilities: pm pciexpress msi bus_master cap_list
    configuration: driver=snd_hda_intel latency=0
    resources: irq:149 memory:efe60000-efe63fff
    *-usb
    description: USB controller
    product: 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller
    physical id: 14
    bus info: pci@0000:00:14.0
    version: 31
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi xhci bus_master cap_list
    configuration: driver=xhci_hcd latency=0
    resources: irq:132 memory:eff30000-eff3ffff
    *-usbhost:0
    product: xHCI Host Controller
    vendor: Linux 5.2.14-050214-generic xhci-hcd
    physical id: 0
    bus info: usb@1
    logical name: usb1
    version: 5.02
    capabilities: usb-2.00
    configuration: driver=hub slots=16 speed=480Mbit/s
    *-usb:0
    description: Human interface device
    product: CORSAIR HARPOON RGB WIRELESS Gaming Mouse
    vendor: Corsair
    physical id: 3
    bus info: usb@1:3
    version: 0.05
    serial: EF8730D9DA23EDA7
    configuration: driver=usbhid maxpower=500mA speed=12Mbit/s
    *-usb:1
    description: Keyboard
    product: Corsair Gaming K55 RGB Keyboard
    vendor: Corsair
    physical id: 6
    bus info: usb@1:6
    version: 30.06
    serial: AF359CA25B22EE06F5001BC640048000
    *-usb:2
    description: Bluetooth wireless interface
    vendor: Intel Corp.
    physical id: 8
    bus info: usb@1:8
    version: 0.01
    capabilities: bluetooth usb-2.00
    configuration: driver=btusb maxpower=100mA speed=12Mbit/s
    *-usbhost:1
    physical id: 1
    bus info: usb@2
    logical name: usb2
    version: 5.02
    capabilities: usb-3.00
    configuration: driver=hub slots=10 speed=5000Mbit/s
    *-usb
    description: Mass storage device
    product: My Passport 25E2
    vendor: Western Digital
    physical id: 4
    bus info: usb@2:4
    logical name: scsi6
    version: 40.05
    serial: 575835314443373959344C52
    capabilities: usb-3.10 scsi emulated scsi-host
    configuration: driver=usb-storage maxpower=896mA speed=5000Mbit/s
    *-disk
    description: SCSI Disk
    vendor: WD
    physical id: 0.0.0
    bus info: scsi@6:0.0.0
    logical name: /dev/sda
    version: 4005
    serial: WX51DC79Y4LR
    capabilities: gpt-1.00 partitioned partitioned:gpt
    configuration: ansiversion=6 guid=7039e0e3-9f18-4724-8a04-392457f4065a logicalsectorsize=512 sectorsize=4096
    *-volume
    description: Windows NTFS volume
    vendor: Windows
    physical id: 1
    bus info: scsi@6:0.0.0,1
    logical name: /dev/sda1
    version: 3.1
    serial: 0a85-f07e
    capacity: 3725GiB
    capabilities: ntfs initialized
    configuration: clustersize=4096 created=2018-07-27 11:20:34 filesystem=ntfs label=Games name=stuff state=clean
    *-enclosure UNCLAIMED
    description: SCSI Enclosure
    product: SES Device
    vendor: WD
    physical id: 0.0.1
    bus info: scsi@6:0.0.1
    version: 4005
    *-communication
    description: Communication controller
    product: 100 Series/C230 Series Chipset Family MEI Controller #1
    physical id: 16
    bus info: pci@0000:00:16.0
    version: 31
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi bus_master cap_list
    configuration: driver=mei_me latency=0
    resources: irq:146 memory:eff4d000-eff4dfff
    *-sata
    description: SATA controller
    product: Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode]
    physical id: 17
    bus info: pci@0000:00:17.0
    version: 31
    width: 32 bits
    clock: 66MHz
    capabilities: sata msi pm ahci_1.0 bus_master cap_list
    configuration: driver=ahci latency=0
    resources: irq:133 memory:eff48000-eff49fff memory:eff4c000-eff4c0ff ioport:f050(size=8) ioport:f040(size=4) ioport:f020(size=32) memory:eff4b000-eff4b7ff
    *-pci:1
    product: 100 Series/C230 Series Chipset Family PCI Express Root Port #17
    physical id: 1b
    bus info: pci@0000:00:1b.0
    version: f1
    width: 32 bits
    clock: 33MHz
    capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
    resources: irq:122
    *-pci:2
    product: 100 Series/C230 Series Chipset Family PCI Express Root Port #19
    physical id: 1b.2
    bus info: pci@0000:00:1b.2
    version: f1
    width: 32 bits
    clock: 33MHz
    resources: irq:123
    *-pci:3
    product: 100 Series/C230 Series Chipset Family PCI Express Root Port #20
    physical id: 1b.3
    bus info: pci@0000:00:1b.3
    version: f1
    width: 32 bits
    clock: 33MHz
    resources: irq:124
    *-pci:4
    physical id: 1c
    bus info: pci@0000:00:1c.0
    version: f1
    width: 32 bits
    clock: 33MHz
    resources: irq:125
    *-pci:5
    product: 100 Series/C230 Series Chipset Family PCI Express Root Port #3
    physical id: 1c.2
    bus info: pci@0000:00:1c.2
    version: f1
    width: 32 bits
    clock: 33MHz
    resources: irq:126
    *-pci:6
    product: 100 Series/C230 Series Chipset Family PCI Express Root Port #5
    physical id: 1c.4
    bus info: pci@0000:00:1c.4
    version: f1
    width: 32 bits
    clock: 33MHz
    resources: irq:127 ioport:d000(size=4096) memory:efd00000-efdfffff
    *-network
    description: Ethernet interface
    product: I211 Gigabit Network Connection
    physical id: 0
    bus info: pci@0000:07:00.0
    logical name: enp7s0
    version: 03
    serial: 1c:1b:0d:65:4d:d1
    capacity: 1Gbit/s
    width: 32 bits
    clock: 33MHz
    capabilities: pm msi msix pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
    configuration: autonegotiation=on broadcast=yes driver=igb driverversion=5.6.0-k firmware=0. 6-1 latency=0 link=no multicast=yes port=twisted pair
    resources: irq:16 memory:efd00000-efd1ffff ioport:d000(size=32) memory:efd20000-efd23fff
    *-pci:7
    product: 100 Series/C230 Series Chipset Family PCI Express Root Port #6
    physical id: 1c.5
    bus info: pci@0000:00:1c.5
    version: f1
    width: 32 bits
    clock: 33MHz
    resources: irq:128 memory:efc00000-efcfffff
    *-network
    description: Wireless interface
    product: Wireless 8260
    physical id: 0
    bus info: pci@0000:08:00.0
    logical name: wlp8s0
    version: 3a
    serial: e4:a7:a0:9f:7b:49
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
    configuration: broadcast=yes driver=iwlwifi driverversion=5.2.14-050214-generic firmware=36.77d01142.0 ip=192.168.1.44 latency=0 link=yes multicast=yes wireless=IEEE 802.11
    resources: irq:147 memory:efc00000-efc01fff
    *-pci:8
    product: 100 Series/C230 Series Chipset Family PCI Express Root Port #7
    physical id: 1c.6
    bus info: pci@0000:00:1c.6
    version: f1
    width: 32 bits
    clock: 33MHz
    resources: irq:129
    *-pci:9
    product: 100 Series/C230 Series Chipset Family PCI Express Root Port #8
    physical id: 1c.7
    bus info: pci@0000:00:1c.7
    version: f1
    width: 32 bits
    clock: 33MHz
    resources: irq:130
    *-pci:10
    product: 100 Series/C230 Series Chipset Family PCI Express Root Port #9
    physical id: 1d
    bus info: pci@0000:00:1d.0
    version: f1
    width: 32 bits
    clock: 33MHz
    resources: irq:131 memory:efb00000-efbfffff
    *-storage
    description: Non-Volatile memory controller
    product: SSD 600P Series
    physical id: 0
    bus info: pci@0000:0b:00.0
    version: 03
    width: 64 bits
    clock: 33MHz
    capabilities: storage pm pciexpress msix nvm_express bus_master cap_list
    configuration: driver=nvme latency=0
    resources: irq:16 memory:efb00000-efb03fff
    *-isa
    description: ISA bridge
    product: Z170 Chipset LPC/eSPI Controller
    physical id: 1f
    bus info: pci@0000:00:1f.0
    version: 31
    width: 32 bits
    clock: 33MHz
    capabilities: isa bus_master
    configuration: latency=0
    *-memory UNCLAIMED
    description: Memory controller
    product: 100 Series/C230 Series Chipset Family Power Management Controller
    physical id: 1f.2
    bus info: pci@0000:00:1f.2
    version: 31
    width: 32 bits
    clock: 33MHz (30.3ns)
    capabilities: bus_master
    resources: memory:eff44000-eff47fff
    *-multimedia
    product: 100 Series/C230 Series Chipset Family HD Audio Controller
    physical id: 1f.3
    bus info: pci@0000:00:1f.3
    version: 31
    width: 64 bits
    clock: 33MHz
    configuration: driver=snd_hda_intel latency=32
    resources: irq:148 memory:eff40000-eff43fff memory:eff20000-eff2ffff
    *-serial
    description: SMBus
    product: 100 Series/C230 Series Chipset Family SMBus
    physical id: 1f.4
    bus info: pci@0000:00:1f.4
    version: 31
    width: 64 bits
    clock: 33MHz
    configuration: driver=i801_smbus latency=0
    resources: irq:16 memory:eff4a000-eff4a0ff ioport:f000(size=32)
    *-network
    product: Ethernet Connection (2) I219-V
    physical id: 1f.6
    bus info: pci@0000:00:1f.6
    logical name: enp0s31f6
    version: 31
    serial: 1c:1b:0d:65:4d:d3
    capacity: 1Gbit/s
    width: 32 bits
    clock: 33MHz
    capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
    configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=0.8-4 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
    resources: irq:140 memory:eff00000-eff1ffff
    *-pnp00:00
    product: PnP device PNP0c02
    physical id: 1
    capabilities: pnp
    configuration: driver=system
    *-pnp00:01
    physical id: 2
    capabilities: pnp
    *-pnp00:02
    physical id: 3
    capabilities: pnp
    *-pnp00:03
    product: PnP device PNP0b00
    physical id: 4
    capabilities: pnp
    configuration: driver=rtc_cmos
    *-pnp00:04
    product: PnP device INT3f0d
    physical id: 5
    capabilities: pnp
    *-pnp00:05
    physical id: 6
    capabilities: pnp
    *-pnp00:06
    physical id: 7
    capabilities: pnp
    *-pnp00:07
    physical id: 8
    capabilities: pnp
    *-pnp00:08
    physical id: 9
    capabilities: pnp
    *-power UNCLAIMED
    description: To Be Filled By O.E.M.
    product: To Be Filled By O.E.M.
    vendor: To Be Filled By O.E.M.
    physical id: 1
    version: To Be Filled By O.E.M.
    capacity: 32768mWh
    Try reverting to the previous point release of the kernel.
    Kubuntu 23.11 64bit under Kernel 6.8.7, Hp Pavilion, 6MB ram. All Bow To The Great Google... cough, hack, gasp.
