No In-Built Sound Recording
    Hi, I wanted to do a screencast and used SSR, but the problem is it doesn't record my audio. In pavucontrol configuration I have Bult in Audio > Analog Stereo Output.
    where it said "Analog Stereo Output" if you click it do you get a drop down list , if so select "Analog Stereo Duplex" then look at the "input devices" tab and check the volume settings .
