After change motherboard, WOL not work, or its strange...
    Hi.
    WOL was work perfect in my old motherboard.
    Today, I change my motherboard to MSI x470 Gaming Plus.
    Not reinstall kubuntu, only change motherboard.
    After this change, WOL not work.
    I review all in bios, all is good in bios.
    But I have this strange:
    Start PC, in konsole execute this:
    sudo ethtool -s enp34s0 wol g
    I have this:
    Supports Wake-on: pumbg
    Wake-on: g
    Good, its perfect but not work WOL...
    Then, execute this:
    And then, work fine WOL!!!
    If I restart the computer, I need re-execute sudo ethtool -s enp34s0 wol g for work WOL.
    I don't understand this and I don't know if its issue of motherboard, or I need made some change...
    I search info but I don't view any with this similar problem...
    Thanks in advanced.
    Well, I don't understand it either, but,
    if that is all that's needed, why not just run it at boot.
    System Settings, Startup and Shutdown, Autostart, Add script...
    [EDIT] Knowing the usual behaviour of network interfaces at boot, if it doesn't work, a script with
    sleep 20
    might.
    And of course, if you don't want to type the password, use sudoers.
    See "How to to run sudo command without a password" or similar.
      sleep 20
      might.
      Its a possible solution but...if all its good for WOL, what the reasson that not work WOL, and when execute:
      Works perfect!!
      Its very very strange...
      If I create a script for this, when shutdown the computer, I can't start with WOL...
      Thanks and regards.
      PD: You location its very good, I'm in peninsula
        True. As a temporary fix, you could hibernate/sleep... maybe?
        Because, as I said, I have no idea. Maybe "all is not good in bios"
        But maybe when the time zones get better, someone will.
        Yes, it is
          Yes, as a temporary fix, yes, I caan hibernate/sleep, but I like solved this problem, I don't know the reasson, maybe, like you indicate, all is not good in bios...but I review all in bios and appears well...
          Thanks and regards!
            Have you tried this - from a Google search. There are some other links also, and this one is pretty Windows-centric in the reply, but the basic BIOS info seems to be there. I do NOT have a MSI MB ...
            Intel i7 11th Gen | 16GB | 1TB | KDE Plasma 5.24.7 | Kubuntu 22.04.4 | 6.5.0-18-generic
              Yes, I read the thread that you indicate before post here.
              Also, I open a post in msi forum.
              After this days, I view that, its a "little bug" of new bios, don't have wake on lan option in the bios.
              Like this motherboard I have in guarranty, I prefer change to gigabyte.
              Thanks and regards!
