baloo and Linked Mounts
    Originally, I had two partitions mounted in my home directory using fstab. baloo successfully indexed both partitions.
    I wanted two users to be able to access the same mounted partitions. I have now mounted each partition in /mnt and provided directory links in the ~/ directories.
    baloo no longer indexes any files in the two mounted partitions. I have edited Search in System Settings which had excluded both of the mounted and linked partitions. A reboot fails to add the missing files. I looked for ~/.config/baloofilerc, but it does not exist. 'baloo check' checks for missing files, but nothing is added to the list. A baloo disable and enable does not get the partitions indexed.
    Does anyone know how System Settings/Search saves the baloo config in 18:10 and how linked directories can be included in the baloo search index?
