No matter how many config files I edit or icons I replace, i simply cannot get this icon to change. Does anyone know how to do this? It's driving me nuts! I have also deleted cache and still, nothing. I've tried it in the desktop theme, replaced every instance of the icon in icon themes, and yet it remains. It is the icon in the attached picture of my system tray.
Keyboard Indicator System Tray Icon
Would be my guess that the keyboard indicator icon provided with the theme you are using isn't colored; it's black/white.Using Kubuntu Linux since March 23, 2007
Those icons may or may not be in your theme, therefore reloading the theme, icon cache, etc. is doing nothing.
Look at /usr/share/plasma/desktoptheme/defaut/icons/keyboard.svgz and that's what you're seeing. The icons only change if the theme includes them. You can either edit the default, find a theme with what you want in it, or - and this is the best way to go IMO - copy the default icon into Inkscape, edit it to your liking, edit the theme you are using and include the new icon file.
What icon theme are you using?
I'm using my AmigaBuntu theme that I made myself.I actually did try to include this icon in my theme, but it still does not appear. I made my own by taking the dimentions inside the file mentioned, and then replacing the images with the icons i want. saved it, and placed in directory of my theme, but it does not work. Also, the directory you mentioned has a black colored keyboard icon whereas the one showing for me is white. Also, when i change to a plasma desktop theme that does include an icon for this, for example, oxygen, it still does not show the oxygen keyboard icon but the same one as shown above.
Edit: I just tried also replacing the icon in /usr/share/plasma/desktoptheme/defaut/icons/keyboard.svgz, but it did not work. I tried changing themes and changing back, clearing cache, rebooting. No luck.Last edited by Oderus; Jan 18, 2019, 12:11 PM.
AFAICT the icon is from Breeze-dark, /usr/share/icons/breeze-dark/devices/22/input-keyboard.svg
(I strongly dislike the Breeze stuff; I see horrible Apple brain-damage via the iPad.)
I use Humanity-Dark, which I've hacked to inherit from Humanity,oxygen,Adwaita and hicolor to get more visible icons than the appalling @##$#$@ Breeze ones, which end up as variations of grey on grey with dark colour schemes. But I suspect that because none of Humanity-Dark, Humanity, oxygen, or Adwaita have size 22 icons, I get the Breeze icons in the system tray and the show hidden icons pop-up.
If you have a working, colourful, icon theme for a dark colour scheme, I find that very interesting.Regards, John Little
Originally posted by jlittle View PostAFAICT the icon is from Breeze-dark, /usr/share/icons/breeze-dark/devices/22/input-keyboard.svg
https://store.kde.org/p/1177380/
I have now gone as far as searching for every instance of "input-keyboard*" on my system and replacing all that appear that way. I have also looked for the caplock on icon the indicator uses, also to no avail. I am totally stumped on this one.
I have finally found the solution... apparently the keyboard-indicator used to use the calculator icons but it had been updated. I discovered this here : https://phabricator.kde.org/T9050
After reading this, i used KFind to locate the file, input.svgz here : /usr/share/plasma/desktoptheme/default/icons/input.svgz
Editing this file is a pain, I must admit, since you must not only resize, copy, and paste, your new icons in place, but must also edit the object properties to reflect the settings file for the keyboard-indicator, or just copy them from the old icon before deletion.
But there it is, that's the file, and that's how to edit it. Hope this helps someone.
Originally posted by Oderus View PostI have finally found the solution... apparently the keyboard-indicator used to use the calculator icons but it had been updated. I discovered this here : https://phabricator.kde.org/T9050
https://www.opendesktop.org/p/1295788/
