SpeedStep not working, running hot and noisy
    Hello
    I have some trouble with laptop's fan constantly running. I just installed Kubuntu and it's working very well otherwise. I've had several distros installed on this one and am quite sure that something's different now. Temperature is not really problematic - the fan keeps the system at ~45 Celsius when idle. And it is mostly idling.
    To me it seems the cores are running at the same frequency all the time. For example:
    $ watch -n 0 "lscpu | grep 'MHz'"
    CPU MHz: 2494.319
    CPU max MHz: 3100,0000
    CPU min MHz: 800,0000
    Those stay always the same. And:
    $ grep MHz /proc/cpuinfo
    cpu MHz : 2494.319
    cpu MHz : 2494.319
    cpu MHz : 2494.319
    cpu MHz : 2494.319
    I'm pretty sure that cpuinfo tells the real frequency, since it does vary on my other computers and I'm quite sure it did on this one, too. Scaling settings are:
    $ cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
    powersave
    powersave
    powersave
    powersave
    $ cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_driver
    intel_pstate
    intel_pstate
    intel_pstate
    intel_pstate
    But even though the CPU seems to be running at full speed, it also seems that the governor is really trying to run it slower, like this:
    $ cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_cur_freq
    1077420
    1292360
    1000642
    903888
    I have not touched the BIOS settings for some time but I did make sure that Intel's SpeedStep is enabled. There aren't any performance settings in BIOS at all. I haven't installed anything exotic or tweaked much. I did install Intel microcode update using Muon, but that was just in effort to solve this problem. OS: Kubuntu 17.10, hardware: Lenovo L440 laptop, Intel(R) Core(TM) i5-4200M CPU @ 2.50GHz, 4 GB, ~180 GB SSD.
    Any ideas?
    Added:
    GRUB_CMDLINE_LINUX_DEFAULT="intel_pstate=disable"
    cpu MHz : 900.000
    cpu MHz : 800.000
    cpu MHz : 1800.000
    cpu MHz : 900.000
    Ok for now...
      their is a program for Intel i3,i5 and i7 CPU's to monitor wats going on in real time ,,,,it's "i7z"
        Neat, VINNY! Thanks!
          your welcome ,,,I was trying for the past few days to report on this find , but the .gif I made to show it in action got me blocked from KFN 3 times when trying to upload it,,,,I kinda lost interest in trying further , my bad .
          in KFN's defense the .gif was 20MB in size and Snowhog thinks that maybe the ZB block gave it a false positive as a virus .
          I guess I'll go make that thread using the vid I made the .gif from instead through youtube
