Very Small Fonts in KDE Root Programs - A Solution
    From Volker on kubuntu-users mailing list:
    Hi!
    I've had the problem, that graphical programs (or program parts), which run as root, had a very small font size - such as systemsettings5 or muon's settings->configure software sources window.
    I've investigated it, and I found that the following has to be added to /etc/environment:
    XDG_CURRENT_DESKTOP=KDE
    That is, the XDG_CURRENT_DESKTOP environment variable needs to be set to "KDE". But this doesn't work when set in ~/.bashrc, ~/.proile or /etc/profile. Looks like these scripts aren't called by kdesudo. Instead, it works when the mentionend line is included in /etc/environment (not a script).
    Bye
    Volker
    Mine already has that setting.
    Thank you, KDE Neon dev crew!
      I have it in Kubuntu 16.04 as well. I don't remember setting it. So I'm thinking it's there by default.
      Kubuntu 20.04
