Printer doesn't work on PDFs ?
    To your problem, this doesn't sound like a driver issue to me, but I guess it could be.
    Do you get identical results from both Okular and Evince?
    Are these pdf's you're creating or are they sourced from somewhere else?
    Have you tried any other print methods, like opening them and printing from Libre Office?
      Yes
      From someone else
      No not yet, but I can try that
      Greg
      W9WD
        I just opened the Ferry reservation pdf with LibreOffice Draw and it printed just fine (except it added a blank page)
        Greg
        W9WD
          I see this (the extra page) quite a bit. I think not very many people or services are meticulous when they're creating PDFs.
          At this point, I suspect your source is the issue. Curious is you're looking at these files (the ones with gobbledy-gook) with Print Preview and not seeing the corruption or are you just opening them, then printing?
            I look at the print preview and it looks fine,
            Greg
            W9WD
              Says here not to use the Ubuntu driver: http://foo2xqx.rkkda.com
                But you need to follow that up each time with at least
                sudo apt-get upgrade
                I prefer
                sudo apt-get dist-upgrade
                Don't use 'upgrade'; use 'dist-upgrade'.
                See man apt-get and look at the difference between upgrade and dist-upgrade. The former, if used regularly, will almost certainly end up borking your system. Using dist-upgrade won't.
                  Okular and Evince use a library (called libpoppler IIRC) to print, separate and potentially different from how they display PDF files.
                  I seem to recall seeing updates for libpoppler go by. If, after getting your system fully updated, you're still having trouble you might check out bug reports for libpoppler.
                    Will
                    change my 16.04 install to 17 (etc) ?
                    Greg
                    W9WD
                      No. Open a konsole and type: man apt-get
                      Read what upgrade and dist-upgrade do.
                      Or, https://linux.die.net/man/8/apt-get
                        Somewhat friendlier: https://help.ubuntu.com/community/AptGet/Howto
                        Kubuntu 20.04
                          This is a common problem; people confuse "dist-upgrade" with "do-release-upgrade" all the itme. I suspect that's why the apt developer used "full-upgrade" instead of "dist-upgrade" even though they do the same thing.
                            Ok here's something that really made a difference. I caught this on a YouTube video by accident.
                            sudo apt-get install hplib-gui
                            Now I have all sorts of options little programs and scan stuff etc.
                            Really made a difference.
                            Greg
                            W9WD
                              Big mistake
                              Should have been
                              sudo apt-get install hplip-gui
                              Greg
                              W9WD
