Configuring interface loop on connection
    Hi, i'm having a strange problem since my upgrade from kubuntu 16.10, my network adapter was working and after the upgrade i can't connect to any wifi network.
    If i try to conect via blutooth, it connects without a problem.
    My computer has 2 SO, windows 10, where the usb wifi adapter is working correctly, and kubuntu, where i've tested an usb with kubuntu 17.04 in live mode. So i can't connect with wifi in my installed kubuntu version and in the usb in live mode, in any ocasions the wifi status is configuring interface and then does'nt connect to the network.
    The usb wifi adapter is an Atheros AR9271.
    I'm startin to get suspicious about the support to this adapter. Can anyone give me a help on this?
    Solved, as shown in this post: https://ubuntuforums.org/showthread....2#post13644262
      Thanks for posting that!
      It is some clever Linux Kung Foo!
