cpupower - cpu frequency stuck at lowest 400mhz on UX305 ultrabook pc
    Kubuntu 16.10 Yakkety Yak
    there seemed to be some problems with cpupower binaries installed from apt-get
    based on the guide found at https://blog.sleeplessbeastie.eu/201...ernor-at-boot/
    i installed cpupower sudo apt-get install linux-tools-common linux-tools-$(uname -r)u (note uname -r is 4.8.0-27-generic) then running it
    > sudo cpupower -c all frequency-info
    analyzing CPU 0: driver: intel_pstate CPUs which run at the same hardware frequency: 0
    CPUs which need to have their frequency coordinated by software: 0
    maximum transition latency: Cannot determine or is not supported.
    hardware limits: 400 MHz - 2.20 GHz available cpufreq governors: performance powersave current policy: frequency should be within 400 MHz and 2.20 GHz. The governor "powersave" may decide which speed to use within this range.
    current CPU frequency: 400 MHz (asserted by call to hardware)
    boost state support: Supported: yes
    Active: yes ...
    then i run a heavy compute job but the above command shows that the cpu frequency is stuck at 400 mhz regardless
    then i tried setting the frequency governor to "performance"
    >sudo cpupower -c all frequency-set -g performance
    analyzing CPU 0: driver: intel_pstate CPUs which run at the same hardware frequency: 0 CPUs which need to have their frequency coordinated by software: 0
    current CPU frequency: 400ha
    Active: yes
    the governer didn't get changed using cpupower then as root
    > cd /sys/devices/system/cpu/cpu0/cpufreq
    > echo performance > scaling_governor
    hardware limits: 400 MHz - 2.20 GHz available cpufreq governors: performance powersave current policy: frequency should be within 400 MHz and 2.20 GHz. The governor "performance" may decide which speed to use within this range.
    Active: yes ...
    the cpupower command did not change the scaling governor, it takes updating it directly in /sys filesystem
    and changing the frequency using
    >cpupower -c all frequency-set -f 2.2ghz
    Active: yes ...
    didn't helped at all (it doesn't matter what frequency steps is requested 2ghz, 1ghz, 800mhz etc)
    anyone eise run into the same issue? the Intel processor is m3-6y30
    I think this is the result of this kernel bug -
    https://bugzilla.kernel.org/show_bug.cgi?id=90041
    Spent quite a bit of time with someone on Reddit with the same issue - he found this bug, which appears to have been patched. No idea when the patch will make it into mainstream distros, though.
    -- anais nin
      hi all, an update, due to too little data points when i shutldown and restart my laptop and re-did *different* load tests again, this time round, the cpu frequency become dynamic varying with the loads
      analyzing CPU 0:
      within this range.
      current CPU frequency: Unable to call hardware
      current CPU frequency: 1.40 GHz (asserted by call to kernel)
      Supported: yes
      Active: yes
      analyzing CPU 1:
      CPUs which run at the same hardware frequency: 1
      CPUs which need to have their frequency coordinated by software: 1
      within this range.
      Supported: yes
      Active: yes
      analyzing CPU 2:
      CPUs which run at the same hardware frequency: 2
      CPUs which need to have their frequency coordinated by software: 2
      within this range.
      Supported: yes
      Active: yes
      analyzing CPU 3:
      CPUs which run at the same hardware frequency: 3
      CPUs which need to have their frequency coordinated by software: 3
      within this range.
      Supported: yes
      Active: yes
      sometimes too few data points, cases would trigger the problem, other times it seemed normal
      need to continue monitoring as it seem erratic and application related
        That looks a lot better
        -- anais nin
