Need help getting DVD to mount
    I know the dvd burner worked because it is what I used to install kubuntu.
    I can manually eject and put a disk in and hear it spinning, but it doesn't mount.
    I looked in /dev and there is no file called dvd or cd or sr0 or anything related.
    /media/cdrom is empty.
    dmesg | grep dvd returns nothing
    Any suggestions?
    Not sure if this is the 'real' solution, but see http://askubuntu.com/questions/65344...d-dvd-to-media for a solution that worked.
      Thanks! I tried this but it didn't work. When I looked there is no dev/sr0 so that is probably why it doesn't work.
        no other suggestins on this?
