I need to mount a usb external drive but I can't find /etc/fstab or /etc/mtab. Did ubuntu change things in 15.10? info mount still says to use /etc fstab or /etc/mtab.
Mounting problem
Mounting problem
http://www.kubuntu.org/getkubuntuTags: None
fstab is located in /etc.Using Kubuntu Linux since March 23, 2007
Not there!Just to remind users and devs that Ubuntu and its flavors have a long way to go to be as usr friendly as they should be.
Are you booting off of/running from a Live CD/DVD/USB? When you install from same, an fstab file is created and located in /etcUsing Kubuntu Linux since March 23, 2007
I was running dolphin as the super user and typed left ALT = left . to reveal hidden files but apparently that doesn’t work for fstab and mtab. I exited dolphin and tried pico /etc/fstab but no such package so I tried nano and it displayed a blank file. i tried mtab and that file has all the drives but it still won't mount correctly. I have to drives with the following partition names Steam for Linux and Steam for Linux1 maybe then length is the problem. I suspect the sorting program may simply not go out that far. I will try deleting the new partition later and recreating it using a name that is more unique in the first few letters instead of just the last letter and see if that helps. Seems Like every time I want to add another Steam library, it takes a while to figure out.
= is supposed to be a +. I forgot to to use the shift key.Just to remind users and devs that Ubuntu and its flavors have a long way to go to be as usr friendly as they should be.
Originally posted by steve7233 View PostNot there!
Open a console. Type the following command: ls -la /etc | grep fstab
Press Enter.
You should see:
-rw-rw-r- - 1 root root 731 Dec 17 16:42 fstab
The number/date/time info might be different; the above is from my 16.04 system; but fstab will show. IF IT REALLY DOESN'T, then type:
sudo find / -name fstab
Press Enter.
You should see:
/usr/share/doc/util-linux/examples/fstab
/usr/share/doc/mount/examples/fstab
/etc/fstab
IF YOU DON'T SEE THIS, something is seriously wrong with your system!Using Kubuntu Linux since March 23, 2007
As I said I found it but dolphin apparently can display it also fstab was empty apprently 15.10 only uses mtab.Just to remind users and devs that Ubuntu and its flavors have a long way to go to be as usr friendly as they should be.
Not intending to be pushy or arrogant steve, but you're wrong.
mtab only shows you already mounted partitions; it does not provide any information to the kernel during booting as to what partitions to mount; that is the job of fstab. Please read the man pages for both.
Googled a bit on this though, and there is maybe one possibility that 'may' explain your sitution; maybe.
What is in /etc/systemd/ and, is there a file called system there, and if 'yes', what does it contain?Using Kubuntu Linux since March 23, 2007
steve7233@steve7233-EP45-UD3P:~$ ls /etc/systemd/
bootchart.conf journald.conf logind.conf network resolved.conIt appears to be an empty file. If mtab only shows what is mounted then why does fstab appear to be empty?f system system.conf timesyncd.conf user user.conf
I must have typed it in wrong the other day because now fstab shows stuff Sorry I should have said it appears not to be there instead of just saying Not there in my previous post. Any way...
Code:steve7233@steve7233-EP45-UD3P:~$ ls -la /etc | grep fstab -rw-rw-r-- 1 root root 732 Jul 19 2015 fstab -rw-r--r-- 1 root root 12288 Jun 24 2015 .fstab.swo -rw-r--r-- 1 root root 12288 Jun 24 2015 .fstab.swp steve7233@steve7233-EP45-UD3P:~$
Last edited by steve7233; Apr 19, 2016, 03:13 PM.Just to remind users and devs that Ubuntu and its flavors have a long way to go to be as usr friendly as they should be.
Originally posted by steve7233 View Poststeve7233@steve7233-EP45-UD3P:~$ ls /etc/systemd/
bootchart.conf journald.conf logind.conf network resolved.conf system system.conf timesyncd.conf user user.conf
are you the steve7233 I remember from the old Ultimalinux day's ?
I have to rebbot to see if I solved it. Yes vinney brb.Just to remind users and devs that Ubuntu and its flavors have a long way to go to be as usr friendly as they should be.
Originally posted by steve7233 View PostCode:steve7233@steve7233-EP45-UD3P:~$ ls -la /etc | grep fstab -rw-rw-r-- 1 root root 732 Jul 19 2015 fstab -rw-r--r-- 1 root root 12288 Jun 24 2015 .fstab.swo -rw-r--r-- 1 root root 12288 Jun 24 2015 .fstab.swp steve7233@steve7233-EP45-UD3P:~$
Googling on .fstab.swo and .fstab.swp I found fstab edit and saving problem over on Ubuntu Forums. That you have these two files, and that you say your /etc/fstab file is empty, I'd say that that posting/thread is spot on with what you have here.Using Kubuntu Linux since March 23, 2007
It didn't post my last comment. Maybe I forgot to click post reply.
I thought I had it solved but it boots s read only but I copied the previous drive so why read only unless I made another typo and haven't spotted it yet?
Code:## Steam for Linux1 drive - /dev/sdd1 UUID=11e097bc-6a05-4770-876a-324d35b5947b /media/steve7233/Steam\040for\040Linux1 ext4 rw,relatime 0 2
That's what #9 is.Just to remind users and devs that Ubuntu and its flavors have a long way to go to be as usr friendly as they should be.
