Wifi Icon doesn't display
    Hi
    I can't see the Wireless Icon in the task bar, so, I can't select wifi networks. The problem only happens with my user. I have deleted and then create a default panel, but nothing changes.
    Any help?
    Thanks
    try these.
    1. check system tray settings to be sure you have not set it to hidden or not shown accidentally . (right click in that area) .
    2. change your icon theme to something else and then back. could not be finding the icon and displaying it.. you might be able to click there and see the widget popup .
    (top of thread: thread tools)
      try these.
      I just got this glitch this evening.
      Very helpful that you put this here.
      I checked the area, un-ticked the "networks" checkbox and then ticked again (from the system tray settings) and so I realized that the wi-fi icon was still there, but it became invisible
      So, I changed the theme for the icons, as instructed, and there it was again...
      That means the solution provided by sithlord is working.
      And maybe this thread can be marked as [SOLVED].
        happy to help
          It works, thanks for your help.
            I'm getting the same intermittently with the audio volume applet. Setting it to be hidden in the system tray settings, apply, then to show, apply, brings it back, till the next time.
