HP scanjet doesn't work
    Hi
    I have a HP 8200 Scanjet, but I can't use it. When I type sudo xsane, appears this message:
    "error opening device 'xsane hp scanjet 8200 avision:libusb:005:006' Operation not supported"
    If I type in console:
     sudo sane-find-scanner
      # sane-find-scanner will now attempt to detect your scanner. If the
      # result is different from what you expected, first make sure your
      # scanner is powered up and properly connected to your computer.
      # No SCSI scanners found. If you expected something different, make sure that
      # you have loaded a kernel SCSI driver for your SCSI adapter.
    found USB scanner (vendor=0x131d, product=0x0158) at libusb:006:004
    found USB scanner (vendor=0x067b, product=0x2303) at libusb:005:010
    found USB scanner (vendor=0x03f0 [hp], product=0x0b01 [hp scanjet 8200]) at libusb:005:006
    found USB scanner (vendor=0x03f0 [hp], product=0xb402 [photosmart 7700 series]) at libusb:005:005
    could not fetch string descriptor: Pipe error
      # Your USB scanner was (probably) detected. It may or may not be supported by
      # SANE. Try scanimage -L and read the backend's manpage.
      # Not checking for parallel port scanners.
      # Most Scanners connected to the parallel port or other proprietary ports
      # can't be detected by this program.
    If I type:
    scanimage -L
    device `avision:libusb:005:006' is a Hewlett-Packard ScanJet 8200 flatbed scanner
    I checked also hp-setup , but only dettects printer, not the scanner
    I'm using Kubuntu 15.10 64
    Any help?
    Thanks
    "Operation not supported" sound suspiciously like a permission error. Try to open xsane using kdesudo and see if it lets you access the scanner. I'm not suggesting this is the solution, just a test...
      Thanks for the reply, but I have used "sudo xsane", as you can see in the post. It doesn't work
        Oshun is right - running a gui program with sudo in the commandline can have bad consequences. You should not need admin privileges to run a scanner.
        Doing a quick googs on it, there does seem to be plenty of people having trouble with this scanner - which uses an avision chip, and not an hp one
