Customize installation iso for chromebook.
    I currently use the Kubuntu 14.10 with a chromebook (acer c710). Everything is fine there, after some customizations.
    What I would like to know is if its possible to 'customize' the original Kubuntu iso, To be more precise: the Kubuntu does not recognize the cyapa trackpad, I need to
    modify the /etc/modules after the installation. Is it possible to add those modules into the installation iso? Something like unpack the iso/ edit the /etc/modules then repack.
    rgrds
    chris
    This wiki page probably will help you get started.
      thanks ! Seems this is what I m looking for!
