Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: k9copy fans
  1. Back To Top    #1
    Veteran Member
    Join Date
    Aug 2006
    Posts
    436
    Threads
    23
    Local Date
    Dec 19th 2018
    Local Time
    08:56 AM
    k9copy fans
    if your like me, you just can't adjust to k9copy being gone.
    get source from here. http://k9copy.sourceforge.net/web/index.php/en/download extract.
    Prerequisites are here. http://k9copy.sourceforge.net/web/index.php/en/ I had to install(You might need more):
    sudo apt-get install kdelibs5-dev libxine-dev libmpeg2-4-dev libavformat-dev libswscale-dev
    create build directory next to extracted directory. and:
    cmake -DCMAKE_BUILD_TYPE=Debug -DQT_QMAKE_EXECUTABLE=qmake-qt4 -DCMAKE_CXX_FLAGS:STRING="-Wall -fno-omit-frame-pointer -ggdb" ../source
    Where "../source" is the path to the extracted directory.
    make -j4
    I didn't install it and it ran fine from the build directory. The menu and toolbars where slim, but I believe that was from the lack of installation. I had to edit the toolbar to get to the copy command. Not a big deal.
    I am curious about the qt only version.
    FKA: tanderson
  2. Back To Top    #2
    Isomorphic Algorithm MoonRise's Avatar
    Join Date
    May 2006
    Location
    SC
    Posts
    5,013
    Threads
    371
    Local Date
    Dec 19th 2018
    Local Time
    07:56 AM
    Thanks for the information. I actually had to take a DEB from the older REPOS and used that to install. Seems fine but I agree it is hard to get use to it not being available any more.
  3. Back To Top    #3
    Veteran Member
    Join Date
    Aug 2006
    Posts
    436
    Threads
    23
    Local Date
    Dec 19th 2018
    Local Time
    08:56 AM
    I have tried others and I just can't get myself to spend the time to learn them.
    I can't believe it is left out of the repo's. I didn't have to do anything to the code. Must be the original author was doing the packaging.
    FKA: tanderson
  4. Back To Top    #4
    Veteran Member
    Join Date
    Aug 2006
    Posts
    436
    Threads
    23
    Local Date
    Dec 19th 2018
    Local Time
    08:56 AM
    I had to make some minor changes to the k9copy code for trusty. Seems to be working here.
    https://github.com/blobfish/k9copy
    FKA: tanderson
  5. Back To Top    #5
    Esteemed Member life0riley's Avatar
    Join Date
    Feb 2013
    Location
    Salem, OR, USA
    Posts
    569
    Threads
    27
    Local Date
    Dec 19th 2018
    Local Time
    04:56 AM
  6. Back To Top    #6
    Veteran Member perspectoff's Avatar
    Join Date
    Nov 2008
    Location
    Outer Milky Way
    Posts
    319
    Threads
    12
    Local Date
    Dec 19th 2018
    Local Time
    12:56 PM
    Gosh, I used k9copy religiously for years, and its best value was the built-in DVD9 -> DVD5 shrinkage feature. It was just a front-end, after all, though. I don't think I've used it for the past 3 or 4 years.
    I think the k9copy author's saying that "the DVD is dead" is pretty much true these days. I now only use DVDs to store files once-in-a-while, and for videos I only use the DVDs to occasionally store the .MKV (or .MP4 or .AVI) files on them anyway (for which K3b works just fine). Large-capacity hard drives (and even USB drives or SDcards) are dirt-cheap and it's much easier to throw the video files onto one of them (rather than to keep track of multiple DVDs). Besides, DVDs are finicky beasts, and scratches and smudges ruining a DVD are memories of the past.
    Lastly, I can't remember the last time I played a DVD (.VOB-based or any other format) in the DVD player (which reads video files from a USB-based external hard drive better than from a DVD anyway).
    Nowadays if I find a .VOB video DVD lying around (I used to produce all my work presentations on DVDs), I generally convert it immediately to .MKV (using Handbrake) or to .AVI (using mencoder) and then throw it onto the hard-drive. (See (K)Ubuntuguide at http://ubuntuguide.org/wiki/Video_Conversion .)
    I've read that for personal-use purposes the "ripping" process will be legal in the UK starting in July 2014 even for commercial DVDs (though the US isn't so progressive and it will still remain illegal there).
    [rant]
    I do have a beef with repo managers removing old, stable programs from the repos because "they are not actively being developed" anymore, though. Simple, stable front-end programs do not always need a heck-of-a-lot of development year by year... In fact, the rabid desire for (often unnecessary) rapid change is, IMO, what often introduces so many new bugs into platforms. It's one of the reasons I've gone to LTS releases only.
    [/rant]
    UbuntuGuide/KubuntuGuide
    Right now the killer is being surrounded by a web of deduction, forensic science,
    and the latest in technology such as two-way radios and e-mail.
  7. Back To Top    #7
    Join Date
    Feb 2013
    Location
    Salem, OR, USA
    Posts
    569
    Threads
    27
    Local Date
    Dec 19th 2018
    Local Time
    04:56 AM
    I agree. The DVD is becoming obsolete. I've converted most of our home movies from DVDs to .MKV using Handbrake. It's much more convenient to watch them from the computer.
    I was reacting to the latter part of this statement here.
    The DVD is obsolete, and I no longer believe in the future of desktop Linux.
    I can see where developing an application that works with all the major distributions would be time consuming and challenging. If I had that skill set it would be a labor of love for me.
    Quote from here.
    The third is that all my efforts to switch to Linux have been unsuccessful. Seven years later, I still have a dual boot Windows / Linux, and I am still forced to use Windows applications. I do also think that this situation could change, however, and for this reason that I stop everything. I stop to get involved in a fight that is not mine but that of large corporations trying to take advantage of this operating system to reap healthy profits (when they arrive).
    I'm more realistic. As much as I'd like to, I know I will never get away from Windows completely. It's the OS of choice where I work, and my wife and the rest of our family could not make the transition.
    Quote Originally Posted by perspectoff View Post
    [rant]
    [/rant]
    Exactly! My main computer is LTS. I'm not ready to part yet with some programs I find useful.
  8. Back To Top    #8
    Newbie
    Join Date
    Apr 2014
    Posts
    4
    Threads
    0
    Local Date
    Dec 19th 2018
    Local Time
    07:56 AM
    I know there were some other things I had download (though I can't for life of me remember what ), but I simply downloaded a copy of the old avformat.h from the net - one that said something about MIT on it. This header contains the structure AVFormatParameters and contains the cur_st member in the struture AVFormatContext. I put the header in file in a new subfolder - src/includes, and changed 2 k9copy headers to include that path and it builds and runs fine.
    For those who may not know: besides the "DVD is going away" thing, there is another larger reason why k9copy isn't in Ubuntu now. A couple of years ago there was dissent in the ffmpeg community which resulted in another project being created called libav. Debian & Ubuntu have selected to go with libav and not include/support ffmpeg anymore. So there is a larger thing at work here. To truely get this working in Ubuntu in a way which would probably be acceptable to Ubuntu/Debian, it would have to exclude the depedency on ffmpeg, which means the k9copy code would have to be converted to use libav instead. I have created a post in the Ubuntu forums asking for guidance on ffmpeg to libav conversion in general.
    It's too bad - either one maintains 2 code bases - 1 for Debian/Ubuntu, 1 for distros that include ffmpeg, or one must make their product exclusive of the other, thus limiting the potential audience. Just because of conflicting personalities and views of how ffmpeg should be maintained.
  9. Back To Top    #9
    Newbie
    Join Date
    Apr 2014
    Posts
    4
    Threads
    0
    Local Date
    Dec 19th 2018
    Local Time
    07:56 AM
    Quote Originally Posted by blobfish View Post
    I didn't realize what you meant was that you had already made the changes so that k9copy would build in Ubuntu and the libav environment. That saves me trying to figure out any of this. Have you submitted this for inclusion in Ubuntu repos?
    Great work, and thank you!
  10. Back To Top    #10
    Veteran Member
    Join Date
    Aug 2006
    Posts
    436
    Threads
    23
    Local Date
    Dec 19th 2018
    Local Time
    08:56 AM
    Quote Originally Posted by squakie View Post
    No. Not sure how far I want to go.
    FKA: tanderson
Similar Threads
  1. Any amiga fans out there?
    By runequester in forum Kubuntu or Linux Discussions
    Last Post: May 18th 2011, 08:16 AM
  2. For Tweety fans
    By StarWolf in forum Artwork
    Last Post: Jul 29th 2010, 06:11 PM
  3. k9copy crashes
    By lowrider in forum Software Support
    Last Post: Nov 9th 2009, 07:16 PM
  4. Turning on fans?
    By shadowfx78 in forum Hardware Support
    Last Post: Nov 16th 2007, 01:25 AM
  5. for you yoda fans
    By StarWolf in forum Kubuntu Catchall
    Last Post: Apr 21st 2007, 03:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
