An unresolvable problem occurred while calculating the upgrade.
    When running the do-release-upgrade, I get the error "An unresolvable problem occurred while calculating the upgrade."
    $ sudo do-release-upgrade -d
    Checking package manager
    Reading package lists... Done
    Building dependency tree
    Building data structures... Done
    Calculating the changes
    Could not determine the upgrade
    This can be caused by:
    * Upgrading to a pre-release version of Ubuntu
    * Running the current pre-release version of Ubuntu
    * Unofficial software packages not provided by Ubuntu
    If none of this applies, then please report this bug using the
    command 'ubuntu-bug ubuntu-release-upgrader-core' in a terminal.
    Restoring original system state
    root@Jupiter:/var/log/dist-upgrade# cat main.log | grep ERROR
    2013-10-19 11:41:09,993 ERROR Dist-upgrade failed: 'E:Unable to correct problems, you have held broken packages.'
    root@Jupiter:/var/log/dist-upgrade# cat apt.log | grep -i broken
    Broken cups-filters:amd64 Conflicts on ghostscript-cups [ amd64 ] < 9.07~dfsg2-0ubuntu3.1 > ( text )
    Broken libpam-systemd:amd64 Conflicts on libpam-xdg-support [ amd64 ] < 0.2-0ubuntu2 > ( admin )
    Broken libwayland-client0:amd64 Conflicts on libwayland0 [ amd64 ] < 1.0.5-0ubuntu1 > ( libs ) (< 1.1.0)
    Broken libharfbuzz0a:amd64 Breaks on libharfbuzz0 [ amd64 ] < 0.9.13-1 > ( libs )
    Broken libharfbuzz0a:amd64 Breaks on libharfbuzz0 [ i386 ] < 0.9.13-1 > ( libs )
    Broken libsnmp30:amd64 Breaks on libsnmp15 [ amd64 ] < 5.4.3~dfsg-2.7ubuntu1 > ( libs )
    Broken python3-uno:amd64 Conflicts on python-uno [ amd64 ] < 1:4.0.4-0ubuntu1 > ( python )
    Broken xserver-xorg-video-mach64:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    Broken xserver-xorg-video-trident:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    Broken xserver-xorg-video-sis:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    Broken xserver-xorg-video-siliconmotion:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    Broken xserver-xorg-input-vmmouse:amd64 Depends on xorg-input-abi-18 [ amd64 ] < none > ( none )
    Broken xserver-xorg-video-savage:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    Broken xserver-xorg-video-intel:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    Broken xserver-xorg-video-r128:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    Broken xserver-xorg-video-vesa:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    Broken xserver-xorg-video-s3:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    Broken xserver-xorg-video-fbdev:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    Broken xserver-xorg-video-nouveau:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    Broken xserver-xorg-video-neomagic:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    Broken xserver-xorg-video-sisusb:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    Broken xserver-xorg-video-cirrus:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    Broken xserver-xorg-input-mouse:amd64 Depends on xorg-input-abi-18 [ amd64 ] < none > ( none )
    Broken lib32asound2:amd64 Depends on libasound2 [ amd64 ] < 1.0.25-4ubuntu3.1 -> 1.0.27.2-1ubuntu6 > ( libs ) (= 1.0.25-4ubuntu3.1)
    Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-cirrus [ amd64 ] < 1:1.5.2+git20130108.e2bf5b25-0ubuntu0sarvatt > ( x11 )
    Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-fbdev [ amd64 ] < 1:0.4.3+git20120801.2edaad4a-0ubuntu0sarvatt > ( x11 )
    Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-intel [ amd64 ] < 2:2.99.904+git20131009.b9ad5b62-0ubuntu0sarvatt~raring > ( x11 )
    Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-neomagic [ amd64 ] < 1:1.2.7+git20120912.bc78be1c-0ubuntu0sarvatt > ( x11 )
    Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-nouveau [ amd64 ] < 1:1.0.9+git20130730.300c5a32-0ubuntu0sarvatt~raring > ( x11 )
    Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-s3 [ amd64 ] < 1:0.6.5+git20120912.92d10d5d-0ubuntu0sarvatt > ( x11 )
    Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-savage [ amd64 ] < 1:2.3.6+git20120801.3d181030-0ubuntu0sarvatt > ( x11 )
    Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-siliconmotion [ amd64 ] < 1:1.7.7+git20120801.2beb25bd-0ubuntu0sarvatt > ( x11 )
    Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-sis [ amd64 ] < 1:0.10.7+git20120912.339fb3bc-0ubuntu0sarvatt > ( x11 )
    Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-sisusb [ amd64 ] < 1:0.9.6+git20120801.894814fe-0ubuntu0sarvatt > ( x11 )
    Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-trident [ amd64 ] < 1:1.3.6+git20120801.3098fe71-0ubuntu0sarvatt > ( x11 )
    Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-vesa [ amd64 ] < 1:2.3.2+git20120912.7aafaf56-0ubuntu0sarvatt > ( x11 )
    Broken xserver-xorg-input-all:amd64 Depends on xserver-xorg-input-vmmouse [ amd64 ] < 1:12.9.0+git20120813.dba73ceb-0ubuntu0sarvatt > ( x11 )
    Broken xserver-xorg-video-ati:amd64 Depends on xserver-xorg-video-r128 [ amd64 ] < 6.9.1+git20130104.24f28a78-0ubuntu0sarvatt > ( x11 )
    Broken xserver-xorg-video-ati:amd64 Depends on xserver-xorg-video-mach64 [ amd64 ] < 6.9.4+git20130104.80e62cc1-0ubuntu0sarvatt > ( x11 )
    Broken xserver-xorg-input-wacom:amd64 Depends on xorg-input-abi-19 [ amd64 ] < none > ( none )
    Broken xserver-xorg-input-synaptics:amd64 Depends on xorg-input-abi-19 [ amd64 ] < none > ( none )
    Broken libxi6:amd64 Breaks on xserver-xorg-core [ amd64 ] < 2:1.13.4~git20130508+server-1.13-branch.10c42f57-0ubuntu0ricotz~raring -> 2:1.14.3-3ubuntu2 > ( x11 ) (< 2:1.14)
    Broken xserver-xorg-video-all:amd64 Depends on xserver-xorg-video-ati [ amd64 ] < 1:7.1.99+git20130730.6a278369-0ubuntu0sarvatt~raring -> 1:7.2.0-0ubuntu10 > ( x11 )
    Broken xserver-xorg-video-ati:amd64 Depends on xorg-video-abi-13 [ amd64 ] < none > ( none )
    I see it's mostly, but not all, xorg related. I have just removed the xorg-edgers repo, but how do I now replace all the installed stuff with stock versions?
    Thanks.
    Intocabile
    did you run the xorg-edgers purge ppa app?
      No. I had no idea there was one.
      Intocabile
        $ sudo ppa-purge xorg-edgers
        PPA purged successfully
        Right. Let's see what happens next ...
        Thanks for the tip.
        Intocabile
          Yep, that was it.
          Thanks
          Intocabile
            aye sir
              I get " sudo: ppa-purge: command not found " And still gave the same error...
                Have you installed ppa-purge from muon (or sudo apt-get install ppa-purge)?
                Intocabile
                  Thanks for your help... I know I'm getting closer to Upgrade
                  Now I get: ""
                  Updating packages lists
                  W: Failed to fetch http://ppa.launchpad.net/jonoomph/op...-i386/Packages 404 Not Found
                  E: Some index files failed to download. They have been ignored, or old ones used instead.
                  Warning: apt-get update failed for some reason
                  PPA to be removed: xorg-edgers ppa
                  Warning: Could not find package list for PPA: xorg-edgers ppa
                  I guess my mess is even bigger...
                    And xorg-edgers is in your list of sources/PPAs?
                    Intocabile
                      That's weird my reply didn't show up so I will try to repost.
                      I have a similar problem but with a Intel Graphics driver -Ubuntu's version doesn’t work for the Intle GMA 45-.
                      steve7233@steve7233-HP-Pavilion-dv6-Notebook-PC:~$ sudo ppa-purge Intel Graphics drivers
                      PPA to be removed: Intel ppa
                      Warning: Could not find package list for PPA: Intel ppa
                      I could not remember the name of the package so I looked at my software sources and guessed. Did I get the name wrong or is it something else?
                        ppa-purge is a tool that uninstalls all packages from a PPA and also removes the PPA from your list of package sources.
                        In the context here, some people have had to purge the Xorg Edgers PPA, which is commonly used to provide a more up-to-date Xorg stack and set of video drivers. Do you know whether you're using this PPA?
                          I was but I found out about an Intel driver that runs my Intel GMA 45 even better. It's the closed source diver where Ubuntu’s Intel driver is the open source which doesn’t work with every Intel GPU. I figured I was having the same problem since my GPU driver isn't an official Ubuntu package.
                            You will need to check with whomever you obtained the driver from to determine if they've released a version for Saucy, then. Do you recall where you downloaded it?
                              https://downloadcenter.intel.com/Det...adType=Drivers
                              It's the generic version of their driver. I don't know why this one works for me and the Ubuntu package does not. For some reason things just work better for me than with the Ubuntu version. For example Star Trek Online will not display correctly with the Ubuntu version. Team Fortress 2 will not display at all with the Ubuntu package in fact TF2 will not display with Xorg-Edgers either. I suspect Hewlett Packard Probably altered the Intel GMA 45 in this computer so that it uses their driver. It works just fine in Windows but Linux has difficulties. Typical arrogant computer manufacturers. They probably have a deal with Mico$oft.
