Manual Network Connection
This is a sticky topic.
    I have a strange problem with my DSL connection.
    I use the widget Network Manager to connect to the wifi. The I run
    sudo pppoeconf
    to establish the pppoe connection. Everything works fine.
    If a shut down the PC, however, when turning on again it happens that Network Manager does not see anymore any wifi available.
    Of course, I can see them by running
    sudo iwlist scan
    There is a solution, I just have to comment all the lines in
    /etc/network/interfaces
    and reboot.
    So, somewhere, somehow, pppoeconf is modifying those configuration file in a way that Network manager does not like.
    Here is the interfaces file that is not working:
    auto lo
    iface lo inet loopback
    auto dsl-provider
    iface dsl-provider inet ppp
    pre-up /sbin/ifconfig eth0 up # line maintained by pppoeconf
    provider dsl-provider
    auto wlan0
    iface wlan0 inet manual
    auto eth0
    iface eth0 inet manual
    any suggestion is appreciated
    best,
    g.
    ---------------<br />Linux kernel 2.6.28-15-generic<br />Kubuntu 9.04 64bit KDE 4.2.2<br />Dell Precision M2400 Intel Dual Core 2<br />Nvidia Quadro FX 370M (Driver Nvidia 180.44)<br />HDA Intel (STAC92xx Analog)<br />---------------
    Install Wicd.
      Have a look also at this http://kubuntuforums.net/forums/inde...opic=3104329.0
      HP Compaq nc6400, 2Gi, 100Gi, ATI x1300 with 512M
        And another reference: How To: Manual Network Configuration without the need for Network Manager over on Ubuntuforums.org
          Re: Manual Network Connection
          @snowhog: Your reference to UFO ??
            Geez, I feel like a total noob! Fixed. Thank you.
