Project Neon
This is a sticky topic.
    Re: Project Neon
    Originally posted by toad
    I've got all my apps but there is no lancelot in sight
    Apart from that they are coding like like there's no tomorrow
    Can't see any applications and Lancelot doesn't run, but I can wait!
      Re: Project Neon
      I myself removed kde-nightly today. My poor ISP isn't good enough to handle 180mb of daily updates. I loved the UI, but perhaps, I'd install it on a VM as it crashes often.
      But well, I'm not complaining.. great work by apachelogger!
        Re: Project Neon
        WAY TO GO GUYS !!!
        This is what we've been waiting for !
          Re: Project Neon
          Originally posted by artisan
          WAY TO GO GUYS !!!
          Have you got the applications in Kickoff? I downloaded 170 mb the other day and still cannot see them.
          Lancelot wont run either.
            Re: Project Neon
            from here
             cp /etc/xdg/menus/kde4-applications.menu ~/.config/menus/applications.menu
            and rerun kbuildsycoca4
            got my apps and file associations this way a week ago
              Re: Project Neon
              No applications menu either... well, it's also empty I mean.
              I'll do with yakuake and command line for the time being. :-)
                Re: Project Neon
                Yep, that worked thanks.
                  Re: Project Neon
                  Thanks for the fix, Musta!
                  Is it probably better to do a symlink? Also, is this going to overwrite the KDE4.1 menu? This is a bit of a concern, maybe we should contact apachelogger and ask ...
                    Re: Project Neon
                    Hello,
                    just read the previous page of this thread (5th post, if you do not want to read the other four.)
                      Re: Project Neon
                      Okay. This is looking deliciously awesome at this point.
                      Just one problem/question. Is anyone else having difficulty with akregator? For whatever reason, it won't fetch any feeds. Konqueror works a treat, so it's not the internet connection. The same feeds fetch fine KDE 4.1
                      Any suggestions? Or should I just wait?
                        Re: Project Neon
                        I'm seeing the same problem with Akregator.
                          Re: Project Neon
                          Akregator from within Kontact works just fine over here.
                          4 GB Ram
                          Kubuntu 18.10
                            Re: Project Neon
                            I had this problem as well with an earlier version, in addition to a bunch of kio_http's and akregator hogging the cpu to 100%. The newer versions seem to have fixed that. Did you perform an update lately?
                            Anyway, my KDE4.2 works  great after I wiped the original ~/.kde-neon folder and copied ~/.kde to ~/.kde-neon.
                              Re: Project Neon
                              Is anyone running these packages on 64bit? I'd love try them but I'm afraid I'll bork my system if I install them.
                                Re: Project Neon
                                I really don't think you can bork your system. These packages do not interfere with your base installation, as far as I can tell. And they are easily removable by simply uninstalling the packages. Unless you log out and choose to start a KDE Nightly session you would never know they were there at all.
