help with languages ??
    i'm now downloadin Kubuntu d.10 dvd 3.93 GB
    i was wondering if it support arabic ??
    coz i'm setting now to windows and i never used linux befor and that would be my first time
    can someone tell simple installation procedure
    ( i wasnt to use linux alone i hate dual pc )
    also i don't wana lose my data ?? so can some one help
    Re: help with languages ??
    Yes. It supports arabic
    Put the DVD in your DVD-Rom. Make sure the BIOS is set to boot from CD. Start computer. Do you need more information than that?
    Do you mean you WANT to use Linux alone and not dual boot?
    What kind of data do you have and do not want to lose?
    "A problem well stated is a problem half solved." --Charles F. Kettering
    "Sometimes the questions are complicated and the answers are simple."--Dr. Seuss
      sorry for bad writting
      yes i men that i want to use linux alone
      and i heard that linux installation reformat the whole HD so can i just use paragon to convert the type of my file system befor installing ??
      i have data like movies mp3 also my college books
      sure i don't wann lose them
      can you help ??
