[SOLVED] DSL problem
    I have a strange problem with a DSL connection (Alice ADSL for the Italian readers).
    Wiht WICD I can connect to the router without problem, there is a WPA key that is recognized. My ifconfig and iwconfig are copied below.
    I then run
    sudo pppoeconf
    and insert the new password while accepting all the default options. The plog command seems to be fine:
    gianluca@trinity:~$ plog
    May 27 11:56:54 trinity pppd[17051]: Using interface ppp0
    May 27 11:56:54 trinity pppd[17051]: Connect: ppp0 <--> wlan0
    May 27 11:56:55 trinity pppd[17051]: PAP authentication succeeded
    May 27 11:56:55 trinity pppd[17051]: peer from calling number 00:90:1A:A0:8E:57 authorized
    May 27 11:56:55 trinity pppd[17051]: not replacing existing default route via 192.168.1.1
    May 27 11:56:55 trinity pppd[17051]: Cannot determine ethernet address for proxy ARP
    May 27 11:56:55 trinity pppd[17051]: local IP address 87.18.37.175
    May 27 11:56:55 trinity pppd[17051]: remote IP address 192.168.100.1
    May 27 11:56:55 trinity pppd[17051]: primary  DNS address 85.37.17.11
    May 27 11:56:55 trinity pppd[17051]: secondary DNS address 85.38.28.69
    however, I'm not connected to the internet. From firefox I can also access to the router configuration interface and verify that my connection on the router is working.
    As additional info, with kubuntu 8.04 it worked perfectly.
    Any idea?
    Thanks in advance,
    g.
    gianluca@trinity:~$ ifconfig
    eth0   Link encap:Ethernet HWaddr 00:21:70:d7:63:a1
         UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
         RX packets:0 errors:0 dropped:0 overruns:0 frame:0
         TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
         collisions:0 txqueuelen:1000
         RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
         Memory:f6fe0000-f7000000
    lo    Link encap:Local Loopback
         inet addr:127.0.0.1 Mask:255.0.0.0
         inet6 addr: ::1/128 Scope:Host
         UP LOOPBACK RUNNING MTU:16436 Metric:1
         RX packets:190 errors:0 dropped:0 overruns:0 frame:0
         TX packets:190 errors:0 dropped:0 overruns:0 carrier:0
         collisions:0 txqueuelen:0
         RX bytes:16821 (16.8 KB) TX bytes:16821 (16.8 KB)
    pan0   Link encap:Ethernet HWaddr 76:22:d3:67:fc:45
         inet6 addr: fe80::7422:d3ff:fe67:fc45/64 Scope:Link
         TX packets:9 errors:0 dropped:0 overruns:0 carrier:0
         RX bytes:0 (0.0 B) TX bytes:540 (540.0 B)
    wlan0   Link encap:Ethernet HWaddr 00:21:6a:2d:b4:c2
         inet addr:192.168.1.18 Bcast:192.168.1.255 Mask:255.255.255.0
         inet6 addr: fe80::221:6aff:fe2d:b4c2/64 Scope:Link
         RX packets:23626 errors:0 dropped:0 overruns:0 frame:0
         TX packets:27355 errors:0 dropped:0 overruns:0 carrier:0
         RX bytes:15163761 (15.1 MB) TX bytes:7028756 (7.0 MB)
    wmaster0 Link encap:UNSPEC HWaddr 00-21-6A-2D-B4-C2-00-00-00-00-00-00-00-00-00-00
    gianluca@trinity:~$ iwconfig
    lo    no wireless extensions.
    eth0   no wireless extensions.
    wmaster0 no wireless extensions.
    wlan0   IEEE 802.11abgn ESSID:"Alice-26382430"
         Mode:Managed Frequency:2.412 GHz Access Point: 00:1D:8B:41:75:2D
         Bit Rate=18 Mb/s  Tx-Power=15 dBm
         Retry min limit:7  RTS thr:off  Fragment thr=2352 B
         Power Management:off
         Link Quality=100/100 Signal level:-41 dBm Noise level=-87 dBm
         Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
         Tx excessive retries:0 Invalid misc:0  Missed beacon:0
    pan0   no wireless extensions.
    ---------------<br />Linux kernel 2.6.28-15-generic<br />Kubuntu 9.04 64bit KDE 4.2.2<br />Dell Precision M2400 Intel Dual Core 2<br />Nvidia Quadro FX 370M (Driver Nvidia 180.44)<br />HDA Intel (STAC92xx Analog)<br />---------------
    Re: DSL problem
    It may be that you have not established a default route. That is the route that will be used to find any address that is not on your local network, which is just about everything. To find out run
    route
    It should show something like this
    Kernel IP routing table
    Destination Gateway Genmask Flags Metric Ref Use Iface
    192.168.0.0 * 255.255.255.0 U 0 0 0 eth0
    default 192.168.0.100 0.0.0.0 UG 0 0 0 eth0
    pppd has an option of defaultroute which will establish this.
      Re: DSL problem
      my
      /etc/ppp/peers/dsl-provider
      already have the defaultroute option uncommented.
      Is is what you meant?
      thanks,
      g.
      the command route gives:
      192.168.1.0   *        255.255.255.0  U   0   0    0 eth0
      default     192.168.1.1   0.0.0.0     UG  0   0    0 eth0
        Re: DSL problem
        I seem to be seeing discrepancies here. Let me see if I can explain them. Your route shows
        And plog showed
        and ifconfig shows
        So your computer has an address in 192.168.1., your default route is 192.168.1.1, which agrees, but then your plog shows "remote IP address 192.168.100.1" which does not agree with the 192.168.1. addresses, so they can not see each other.
        route is saying nothing about wlan0. eth0, which is in your routing table, has no ip address in ifconfig so it is not up.
        Also plog is refering to "local IP address 87.18.37.175" which is a valid internet address and should ba associated with your connection to the outside world, where 192.168.x.x are internal only and must be in your local network.
        It looks like somehow your local and remote ip addresses are reversed and you have a disagreement about the internal network addresses.
        I hope that makes some sense.
        So, what to do about it? Since you are using wicd your /etc/network/interfaces should contain only
        auto lo eth0
        iface lo inet loopback
        Anything else should be commented like
        #auto eth0
        #iface eth0 inet dhcp
        Is your DSL modem acting as your wireless access point also? If so it should be providing addresses that agree with its address but you have the .100. vz .1. error so I am thinking you have another wifi router and the 2 do not agree. I think it might be best to simplify by using the ethernet to get it working and then bring in the wifi.
          [SOLVED] Re: DSL problem
          I solved the problem, it was related to the default route as you suggested.
          In few words I just had to run
          sudo route del default
          and
          sudo route add default gw 0.0.0.0
          where 0.0.0.0 is the local IP address as given by the plog command.
          so, it seems that from the version 8.10 to the version 9.04 there is not an automatic update of the route?
          tanks again. best
          g.
